Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: hatch density
    Junior Member steetie's Avatar
    not specified
    Oct 2005
    austin, tx
    13
    Default hatch density
    i am working on acad 2004. i just hatched an object with the hatch 'dots' and the density 29. i just tried to hatch another object in the same drawing with the same hatch and density, and it's saying it's too small. it's even saying density 60 is too small. i need them to be the same, and i need them closer to the 29 density to show up properly. suggestions?
    Forum Newbie
    Building Systems 2007
    Jun 2007
    4
    Try hatching a larger object such as a really big box at the hatch scale you need. Then move the hatch pattern over the object you intend to hatch and trim the hatch to the object. This problem usually occurs with non-continuous hatch patterns (i.e. dots, concrete, grass), the hatch patterns that don't have continuous lines across them.
    not specified
    Oct 2005
    austin, tx
    13
    How do you trim a hatch?
    Forum Newbie
    Jun 2007
    4
    Command line prompts
    >Trim>Select the object to trim to>Enter>Select the hatch pattern outside the object>Enter
  5. #5
    not specified
    Oct 2005
    austin, tx
    13
    it won't hatch the big box...not with low density, anyway. so i think i'll have to give up and just do the ansi31. that one works, even though it's not the texture i'd like.
  6. #6
    not specified
    Oct 2005
    austin, tx
    13
    oh, and i tried to trim a hatch, just to see if i could do it. when i click on the hatch to trim it, it says 'cannot trim this object'.
  7. #7
    not specified
    Oct 2005
    austin, tx
    13
    so the person i'm doing this for doesn't like the idea of the ansi31 hatch. i tried 'solid'. that one refuses to work at all! i don't understand. it just says 'unable to fill the boundary with solid.'
  8. #8
    not specified
    Oct 2005
    austin, tx
    13
    in case anyone was wondering, my solution is to use ansi31 and give it a density of .25 so it looks solid.
  9. #9
    Full Member jules_s's Avatar
    Architecture 2013
    Nov 2006
    england
    79
    Im pretty sure you cant trim hatch in 2004.
    Have you tried matching the hatch to the first one?
  10. #10
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Sometimes I see just for no reason two hatches looking differrent but the properties window says that they are identicall. Other times I can not use the same hatch pattern I used 5 minutes ago in the same drawing. In all these cases I quickly save my drawings and I restart AutoCAD. If I continue the work usualy I get an error message, something like "hatch pattern can not be read from file" and AutoCAD terminates unexpectedly.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  1. How do I add density to 3D objects?
    By gpktm in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Jan 2007, 11:49 pm
  2. Wire frame density
    By daniel.dascalu in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2006, 06:23 pm
  3. density of material
    By costy in forum AutoCAD Drawing Management & Output
    Last Post: 29th Sep 2005, 09:11 am
  4. hatch density line weight problem?
    By jcarlilesiu in forum AutoCAD Drawing Management & Output
    Last Post: 8th Sep 2005, 04:09 pm
  5. How to hatch
    By Malady in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2004, 04:57 pm
