Combining mtext
Autocad Express Tools allows converting text to mtext. How would I be able to combine multiple mtext into a single mtext?
A routine to do just that is included in:
ToolPac 11.0 by dotsoft. $245 US.
A steep price to pay unless you can make use of the other routines included or you have a great deal of mtext to combine.
  • 8 months later...
That command works, but they are still stacked into lines. I see you can stretch the text by grabbing the handles and modifying it until it is on one line, but then it has spaces between the former lines. Do you know a way of having it do that automatically, and remove spaces where you want to?
Example:
123
456
789
becomes:
123456 789
The space between 3 and 4 removed.
it seems like if there was a way to do the mtext ruler without the dialog box that would be the key. but ddedit and mtedit don't seem to work in command line only.
  • 3 years later...
