Results 1 to 3 of 3
    Senior Member Siberian's Avatar
    Siberian's Computer Details
    Windows 10
    HVAC
    Siberian's Discipline Details
    Engineer, HVAC
    HVAC
    Revit 2019
    Jul 2005
    Norway
    478
    Default Having objects "stay connected" when moved
    I've noticed that dimension lines often stay connected to their objects if you move them, which is very handy, but can this also be done with regular lines that are snaped to objects? Is this effect controled by a variable of some sort?
    If at first you don't succeed - remove all evidence you ever tried.
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    sorry but the "association" is dimension specific only...
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    You can't do this by simply snapping a line to an object, but you can achieve it by creating a dynamic block. Open the attached drawing, click on the block to select it and then grab the blue grip in the center of the circle. You will then be able to drag the circle around on screen and the line will remain attached to the Quadrant snap point. You can also grab the blue grip on the end of the line and stretch it around.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  1. Convert "body" to "Solid"
    By powerdog in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2007, 04:11 pm
  2. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
  3. scaling in "architectural" & "decimal"
    By maze in forum AutoCAD Beginners' Area
    Last Post: 15th Feb 2007, 04:55 pm
  4. Lisp for "dividing" objects
    By fade2blackened in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Mar 2005, 02:55 pm
  5. "Union" Meshes or "Slice" 3D Mesh
    By Peter31712 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 11:11 pm
