Results 1 to 4 of 4
    Dan
    Default AutoCAD to Photoshop. Parsing????
    Whilst going through the AutoCAD to Photoshop turorial, I am coming across a major problem. When i plot to an EPS file and try to open in Photoshop it gives me a 'Could not open the document because the parser module cannot parse the file' I have know idea what this means. Any one.........
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,731
    Dan
    I need to know which version of Photoshop you are using and which PostScript level you used to create the file. I expect you are using PS Level 2 with an older Photoshop (below 6). The solution is simple, use a PostScript Level 1 plotter and it should work fine. See http://www.cadtutor.net/acad/acad2ki/atop/psplot.html for details.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    Dan
    Yes well deduced young Dr Watson, I am using Photoshop 5.5 and post script plotter 2. I will try it with a postcript 1 plotter.
    I am hoping the results will be good enough to put up at a public exhibition and possibly inquiry, the mapping we are using is very detailed do you think this is the best way of getting AutoCAD images into Correll?
    Thanks
    Asus P7P55D-E PRO
    Intel Core i7-860
    Education
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,731
    Ah, that's a whole different question. AutoCAD into Corel Draw. Well I haven't done a tutorial on this just yet but when I last looked, the best option was to go via HPGL. Yes, I know you can import DWG files right into Draw but Draw has a great HPGL import filter that alows you to set line weights, colours etc. So what I do is set up a dummy plotter (like the PostScript technique) but use some standard HP plotter. You can download a driver but AutoCAD does come with some. Then print to file (HPGL). You'll then be able to import the HPGL file into Draw.
    Try it and let me know how you get on.
