Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: linetype
    Super Member happyunited's Avatar
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    Default linetype
    does anyone have a linetype that displays a arrow with a line say for drainage ------->--------? im sure you can make it but i has to change a line a while ago and i found it all a bit hard!
    Senior Member Norts's Avatar
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    the attached file may be a good starting point for you.
    Posting no more
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Try these....
    *CK,---->---->---->----
    A,4,[CKD,akc.shx,s=1.1],4
    *CKU,----<----<----<----
    A,4,[CKU,akc.shx,s=1.1],4
    *CKD,---->---->---->----
    *DRAIN,-->-- - - -->-- - - --
    A,2.05,[CKD,akc.shx,s=1.1],1.95,-0.5,0.5,-0.5,0.5,-0.5,1
    *DRAINU,-- - - --<-- - - --<--
    A,1,-0.5,0.5,-0.5,0.5,-0.5,1.95,[CKU,akc.shx,s=1.1],2.05
    *DRAIND,-->-- - - -->-- - - --
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    Quote Originally Posted by Alan Cullen View Post
    Try these....
    you might want to attach the shape files too Alan
    Posting no more
  5. #5
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    and how would i inset that.lin file into my cad? its 2007
  6. #6
    Map 3D 2009
    Jun 2006
    4,181
    Quote Originally Posted by Norts View Post
    aaaaahhhhhh....good thinking......silly me.......
    Now.....how do I attach a file ??????
  7. #7
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    Quote Originally Posted by happyunited View Post
    you open up notepad (a windows application), then copy and paste the text from Alan's post to the notepad you have open.
    save the file as something appropriate, eg drainage.lin into your support path (this is normally C:\Program Files\AutoCAD 2007\support or something similar).
    then when Alan uploads his shape files, place these into the same directory.
    then go back to autocad, enter Linetype, then press Load button, click on File, navigate to the directory you placed the drainage.lin file into.
    then you should be able to load the linetypes from there.
    Posting no more
  8. #8
    Map 3D 2009
    Jun 2006
    4,181
    Unzip this file and place the files with your acad.lin file.
    Type (findfile "acad.lin") to get the path to your acad.lin file.....then add the code to the end of the file under the ;; User Defined Linetypes section.....
    akc.zip
  9. #9
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    brilliant! thank you. now just waiting on Alan...
    what are shapw files?
  10. #10
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    Attachment 1618
    the last bit has lost me, when i unzip it i get .shp &.shx file what do i do with them? do i still do the other bit with the notepad too?
  1. Linetype
    By johnengineer in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Apr 2007, 11:30 pm
  2. Linetype going crazy
    By Alan Cullen in forum AutoCAD Drawing Management & Output
    Last Post: 19th Oct 2006, 06:31 am
  3. linetype
    By vince in forum AutoCAD Drawing Management & Output
    Last Post: 25th May 2006, 04:41 am
  4. linetype
    By glazier in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2006, 05:59 pm
  5. Layout Linetype
    By keithwhoriskey in forum AutoCAD Beginners' Area
    Last Post: 9th Feb 2006, 02:09 pm
