Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member
    AutoCAD 2009
    Mar 2007
    475
    Question divide line evenly???
    is there a command or even does anyone know a lisp routine to select a line and evenly divide it in to however sections you want?
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,497
    try using the DIVIDE command.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Quote Originally Posted by StykFacE View Post
    In the drop down DRAW>POINT>DIVIDE
    You can get a button as well.
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    you may also want to change your node style so you can locate those points easily
    can't remember how to do it, but I know I started a thread a while back asking how to do it, so you should be able find the answer quite easily
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  5. #5
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Format>Point Style
  6. #6
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    1TB
    Portable TB drive
    Samsung SyncMaster 226
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    Quote Originally Posted by SLW210 View Post
    Format>Point Style
    or type ddptype if your a shortcut junkie
    USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
    If in doubt scale and don't ask!
  7. #7
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Correct me if I'm wrong.....but DIVIDE places points along the line (as opposed to nodes).....
    So the variables required would be.....
    PDMODE .......change the shape/type of point
    PDSIZE ......change the size of the point
  8. #8
    Super Member gcp310's Avatar
    not applicable
    Dec 2002
    physicaly - Australia, mentaly - Another Planet
    696
    i thought nodes and points were the same thing?
    G
  9. #9
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    now, keep in mind that the divide coammnd, or even the measure command, places nodes/points at given intervals but does not actually cut up the line-- or pline-- into seperate entitites...to do that you will either have to BREAK them individually or use a lisp which i think there'S already one around here somewhere...
  10. #10
    Senior Member zars's Avatar
    zars's Computer Details
    Windows Xp Profesional Service Pack 3
    Dell Optiplex 755
    Intel D946GZIS
    Intel Core2Duo 2.13 GHz
    1 GB Kingston DDR2 333 Mhz
    Sata 300 Gb Western Digital
    Dell 17''
    AutoCAD 2007
    May 2006
    LZC, Michoacan, Mexico.
    464
    Measure could be useful as well.
    There are only 2 things which are infinite... the universe and the human stupidity.
    "Life is not the amount of breath you take, it's the moments that take your breath away"
  1. Copy Divide
    By boofredlay in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Mar 2008, 12:23 pm
  2. Divide
    By johnengineer in forum AutoCAD Drawing Management & Output
    Last Post: 13th Apr 2007, 06:11 pm
  3. Divide and Measure
    By CAD-e-Corner in forum AutoCAD RSS Feeds
    Last Post: 12th Sep 2006, 11:40 pm
  4. Divide Icon
    By freddiebear48 in forum AutoCAD Beginners' Area
    Last Post: 13th Jul 2006, 09:47 am
  5. Can I DIVIDE a polyline?
    By CADboy in forum AutoCAD Drawing Management & Output
    Last Post: 15th Jun 2005, 01:01 pm
