Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Senior Member DODGE's Avatar
    AutoCAD 2012
    Oct 2006
    Melbourne The land of Oz.
    444
    Wink Not really AutoCad
    Hi Guys
    Sorry to be asking a none AutoCad related question but this is really
    peeing me off.
    I bought a Seagate Freeagent go 80Gig USB2.0 hard drive the other day. Sort of a king size USB Stick.
    Anyway it's supposed to be a plug and play. Well I did my bit with the plugging but it ain't playing.
    Has anybody had this problem? The only software and drivers it came with were, of course on the unit it self which the computer doesn't recognise. So it just won't work. I took it back to the shop and they plugged it into one of there machines running XP Pro, and of course no problems, it fired up perfect, also on a machine running vista.
    I went to Seagate web site to try and get some info and or drivers, but it's no help. I'm running Win XP Pro and I also tried it on our other machine at home, also running win XP Pro but it's no good in any of them. I thought was a great idea to bring work back and forth to the office, but it's not going to plan. Have any of our AutoCad buddies out there got one of these units and can suggest something I can do to get her running?
    The past 3 weeks I have been jinxed with techno stuff. Two weeks ago I bought a GPS navigation unit that was faulty and had to be exchanged. Then last week I bought my son an Xbox 360 and that was faulty and had to be exchanged for another, which also was faulty ( Whats the chances of that ) When I took that one back the guy decided to tell me that they had had a faulty shipment and had had 7 returned in 1 week. now he's gotta wait another week. Bloody tech stuff I'm going back to 2 tins and a piece of string.
    Ok got all that off my chest, so any help with the Seagate Ta
    Dodge doing his nut.
    Senior Member James's Avatar
    Revit 2009
    Nov 2006
    UK
    357
    hi
    there could be a number of reasons for the unit not to work on your pc, firstly do you have any other USB devices you can plug in the pc to see if they work? as the usb plug & play service may not be running or your USB drivers for the pc are missing/corrupt.
    can you goto control panel>system> the hardware tab>device manager
    do you have any ! marks?
    10100.co.uk ONC/HNC Building Studies :: FCAD32 :: AutoCAD 2009 :: Revit 2009 :: Architectural Technician A.C.I.A.T ::
    Senior Member Norts's Avatar
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    Posting no more
    AutoCAD 2012
    Oct 2006
    444
    Hi Guys
    I am able to plug in normal USB sticks and they fire up fine just not this larger USB Drive. I have also had a look at Seagate site but as I'm not sure what I am doing I havn't downloaded anything to install.
    Thanks for the help so far.
    Dodge
  5. #5
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    Quote Originally Posted by DODGE View Post
    Hi Guys
    Dodge
    In that case, I suggest you look at the link below, see if your device is listed on the page that opens, and take things from there:
    http://www.seagate.com/ww/v/index.js...00dd04090aRCRD
    Posting no more
  6. #6
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    DODGE.....just a bad day mate......should have stayed in bed.....now you know things happen in threes.....don't try to fix it yet......go out and by a quickpick.....that will loose....that will be the three.....then carry on....every thing will suddenly work......."Murphy's Law"
  7. #7
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    also, what usb port are you plugin this into?..directly off the the tower or an unpowered hub?..
    afaik these drives use parasitic, meaning they draw power right off the USB bus...if there's not enough juice then no go which is usually the case on hubs...
    so, hub or tower?..and if tower, do any other USB devices work in those ports?..
  8. #8
    Senior Member zars's Avatar
    zars's Computer Details
    Windows Xp Profesional Service Pack 3
    Dell Optiplex 755
    Intel D946GZIS
    Intel Core2Duo 2.13 GHz
    1 GB Kingston DDR2 333 Mhz
    Sata 300 Gb Western Digital
    Dell 17''
    AutoCAD 2007
    May 2006
    LZC, Michoacan, Mexico.
    464
    So you plug the hd into your usb port and nothing happens??? or the window that notifies you that something has been plugged does appear but you can't see the hd??? if it's the second choice it could be because the hd is new so it's not supposed to have a partition and you have to create it.
    if that's the case then go to control panel -> administrative tools -> computer management -> storage and then disk management, there you'll see if your hd was detected in order to create its partition.
    There are only 2 things which are infinite... the universe and the human stupidity.
    "Life is not the amount of breath you take, it's the moments that take your breath away"
  9. #9
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    Does your drive have 2 USB connectors?
  10. #10
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    Not enough juice man.
