Results 1 to 3 of 3
    Forum Newbie
    Land Desktop 2008
    Jun 2007
    9
    Default How to add a leading zero
    Land Desktop 2008
    I am still having trouble with these pesky line labels.
    I need for the degrees, minutes, and seconds to have two
    digits all of the time whether it is a single digit number or not
    Example:
    I want this: N01°07'23"W
    I currently get this: N1°7'23"W
    Any suggestions?
    Super Member mdbdesign's Avatar
    mdbdesign's Computer Details
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    INTEL CORE 2-QUAD-Q6600@2.4GHz
    4 GB
    NVIDIA GeForce 9800 gt 1gb
    WESTERN DIGITAL 500GB
    2 - 21" COMPACQ
    Mechanical
    mdbdesign's Discipline Details
    Designing Engineer in Engineering Department
    Mechanical
    Pressure tanks Oil processing & storage equip. Steel mill equip. Telecom towers & equip. Wind turbine towers Power plant structures etc.
    AutoCAD 2012
    Jan 2007
    Courtice, Ontario, Canada
    753
    DIMZIN system variable
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    3,000
    Even with DIMAZIN system variable, AutoCAD always has had trouble annotating angles the way surveyors need them to be, i.e. with leading zeroes
    Either you learn to live with it, or get some lisp written for you, or explode the text and manually put in the characters you want.
    For those of us who use the Whole Circle Bearing annotation even the degrees should have three characters, so the label should be 001°07'23"
