Results 1 to 8 of 8
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    Default Visibility problems, AutoCAD2000
    Switching to “layout1” from the model tab, I used “solview” and “soldraw” to make 3 views of my model. So, I got 3 vports. Continuing the work, I added dimensions and so on. Reopening the DWG, just in on of the vports dimensions are visible. But selecting an invisible dimension, it become visible (with dotted line, is selected). If I activate a vport with invisible dimensions, saving, closing and reopening the DWG, that vport has visible dimensions. Checking in the layer manager the visibility of layers, everything looks fine. So?
    Please HEEEELP!
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,640
    Maybe in LAYOUTS you have the layer turned off ? It will still allow you to edit them in MODEL space.
    Click LAYOUT tab and LAYER MANAGER and make all layers visible and NOT frozen within this.
    HTH
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    Thank you, Mr T for your answer.
    As I say, in the layer manager everything is OK. Turning on and unfreezing all layers, all vports will be full of unwanted lines. But dimensions are still visible just in vport active at the time of last save. The printed document is complete, in the model tab dimensions are visible. I reinstalled the AutoCAD, but without results. Can help me anybody?
    AutoCAD 2007
    Nov 2002
    1,640
    Remember that SOLXXXX commands create new layers.
    Also, just thought, you can check your Dimension Style to see if the scaling or other factors have been changed.
    Las resort, check that the active PROFILE is correct, or that the correct profile needs re-importing / re-applying.
    Good luck
    Nick
  5. #5
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    I still have the problem, but I exploded some dimensions and they are visible now (but are no more dimensions). So the problem is not with the visibility of the layer. Is here a system variable controlling the visibility of the dimensions? I don’t think that. However, know somebody a way to list all system variables with a short description, from a single step? Or I must type in each name in the help?
  6. #6
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,739
    You can find a list of all system variables here, http://www.afralisp.com/lisp/acadvar.htm. The list is available in PDF or Word DOC format.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
  7. #7
    AutoCAD 2007
    Nov 2002
    1,640
    >fuccaro"I still have the problem, but I exploded some dimensions and >they are visible now (but are no more dimensions).
    What was the current later when you exploded ?
    >So the problem is not with the visibility of the layer. Is there a system >variable controlling the visibility of the dimensions?
    Yes, hit F1 in Acad and goto the index under commands etc
    there is at least a dozen.
    I think you should check and maybe update the dimensions concerned with the current or new DIMSTYLE. This may be the root of the problem.
    Of course save the file under a new name before doing that.
    Nick[/b]
  8. #8
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    Mr T :
    I use to work with implicit text and dimensions style and I don’t modify them unless very special occasions. So the text stile was standard, using txt.shx font.
    Thank you David for the link, I all ready begun to play around with the system variables (imminent crash?)
    I am still opened for ideas. Any help will be appreciated.
