Try exploring the Sheet Set Manager or the Publish command... I'm not at my regular comp right now so I can't help more but try searching this forum for Sheet Set Manager and you should find something that'll help![]()
hi all
I have autocad lt, I have numerous dwg files in a folder, can anyone supply a script for printing multiple files?
thanks
Dave
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
Explore the ._PUBLISH command.
thanks
but LT does not have the option to print to plotting device in the publish feature
Try a program called GoPlot.
You mean you can only print to DWF using ._PUBLISH....? That doesn't surprise me I suppose....
You could always publish to DWF, then use Design Review to batch plot the DWF's (assuming that you don't have another utility like Repro Desk that can batch plot DWF files)
I have a combination of a batch file, script file, and lisp file that I wrote a few yrs ago that work together to do exactly this. Although, it will take some time to get set up to work for you (file paths etc.). So you will need to be familiar with these types of files. If you want I can post all three. You simply click on the batch file and then sit back and watch.
