Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 35
Thread: Xref help
  1. #11
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,957
    # 500 post for me.
    Attachment 1827
    Attachment 1828
  2. #12
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,957
    Attachment 1829
    This should do it.
    Do you need info on the difference between Bind and Insert in the Pop-up window?
  3. #13
    Junior Member
    AutoCAD 2008
    Jul 2007
    Vancouver
    19
    It won't let me select it, and when I use the pop up "bind" is grayed out. I think I may be turning a little Hulkish right now
  4. #14
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,957
    I will give it in case someone else needs it.
    from AutoCAD help.
    If you use Bind, named objects are prefixed with a blockname$x$ string, where x is a number that is automatically incremented to avoid overriding named objects in the drawing.
    If you use Insert, named objects are merged into the drawing without any prefixes. If duplicate named objects exist, AutoCAD uses the named objects in the drawing. If you do not know whether duplicate named objects exist, use Bind rather than Insert.
  5. #15
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,957
    You may have to reload them.
  6. #16
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,957
    Can you post a screenshot?
  7. #17
    Senior Member
    Architectural DT 2005
    Sep 2006
    334
    SWL210 is right.
    But if your not doing exactly as he says by binding each one separately then your not working with xrefs.
    it must be a block which you can easily explode...
    try purging the layers to reduce the size of the drawing after you explode everything.
    If it is an xref, you need to be careful of circular xrefs... I'e xrefs from within from within another drawing etc... check to see if they are overlays.
  8. #18
    Junior Member
    AutoCAD 2008
    Jul 2007
    Vancouver
    19
    How do I post pics here?
  9. #19
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,957
  10. #20
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,957
    To clarify when you use _xbind you are only able to bind non-graghical info like layers etc.
  1. Xref Fade
    By Hardney in forum AutoCAD Drawing Management & Output
    Last Post: 15th Jul 2010, 06:32 pm
  2. XREF in VB
    By TroutKing in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2008, 07:19 pm
  3. XREF Factor??
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2007, 08:44 pm
  4. Layer states don't transfer from an Xref of an Xref....
    By Dave-CSMW in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2006, 06:02 pm
  5. Xref
    By ebjco in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2006, 03:12 pm
