Results 1 to 3 of 3
    Junior Member
    AutoCAD 2006
    Jul 2007
    24
    Question HELP With Dynamic Blocks Please
    AutoCAD 2008
    Is there any way to change or set the insert handle on a dynamic block without loosing all the dynamic definitions already in the block
    Also wondering if anyone knows if there is anyway to have osnap pick points within a dynamic block without exploding the block .... or any way to snap to a corner within an unexplded dynamic block
    thanks in advance for any advise you may have to offer
    WC
    Junior Member
    AutoCAD 2006
    Jul 2007
    24
    Embarrassed DUH !!! I Think Coyote Has Finally Succumed to RR
    Kindly disregard previous post
    Coyote (Extremeous Stupidous Mooronious) ME
    GEEZ Wonder what base point parameter does ...... maybe it defines the insert ......
    It helps to NOT have the block selected if you are trying to snap something to it. sooooooo
    I must be headed back to ye ole ACME drawing board with me tail between me legs WISHING no one was looking but knowing they WERE
    So sit back had have a quick chuckle at ye ole coyote ITS FREE
    WCjr
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    Go grab a coffee and take a deep breath
    If you're using the move command, and you want to move the block too, snapping to a point on the block, will it do that?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  1. 3D Dynamic Blocks
    By whatispunk in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Apr 2007, 07:44 pm
  2. 3d dynamic blocks
    By wastewater in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Mar 2007, 01:18 am
  3. Dynamic Blocks?
    By The Nickster in forum AutoCAD Drawing Management & Output
    Last Post: 27th Dec 2006, 09:11 pm
  4. Dynamic Blocks
    By xavier in forum Autodesk Software General
    Last Post: 24th Nov 2006, 06:22 pm
  5. Dynamic blocks
    By S.P.I in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jul 2006, 03:34 pm
