+ Reply to Thread
Results 1 to 8 of 8
Thread: Hatch Patterns
  1. #1
    Forum Newbie
    Using
    AutoCAD 2000
    Join Date
    Jul 2007
    Location
    Grafton, Ontario, Canada
    Posts
    3
    Default Hatch Patterns
    Where would I look for non standard Hatch Patterns such as wood grain or
    cord wood? Do I put them in the support file? Are they .pat files? Is this something that someone might share? Are new patterns difficult to make?
  2. #2
    Senior Member James's Avatar
    Using
    Revit 2009
    Join Date
    Nov 2006
    Location
    UK
    Posts
    357
    Default
    i have just been adding custom hatch files to my autocad, how spooky is that!
    these are the sites i came across
    http://www.autocadhatchpatterns.com/
    http://www.cadpanel.com/for_download...h_patterns.htm
    http://xoomer.alice.it/lwcon/retini/retini1.htm
    http://hatchpatterns.com/free_hatch_patterns.php
    http://www.etecad.com/cadslide.htm
    a few to choose from, to add them i did a search and was pretty simple
    you can either make a new custom dir, and add in options>file support
    or just add the codes to your current acad.pat file.
    10100.co.uk ONC/HNC Building Studies :: FCAD32 :: AutoCAD 2009 :: Revit 2009 :: Architectural Technician A.C.I.A.T ::
  3. #3
    Forum Newbie
    Using
    AutoCAD 2000
    Join Date
    Jul 2007
    Location
    Posts
    3
    Default Found The Hatch Links
    Thanks Stilljames,
    Seems a more of a novice than I realized. I'm trying to follow your instructions and trying to fiqure out how to add this without messing with my original .pat file.
  4. #4
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,134
    Default
    Save the original .pat with a new name before editing. I usually just name it Acad_old.pat.
  5. #5
    Banned Alan Cullen's Avatar
    Using
    Map 3D 2009
    Join Date
    Jun 2006
    Location
    Cairns, Queensland, Australia
    Posts
    4,181
    Default
    Find the acad.pat file, and add the new definitions to the end of the file in the User Defined section.....
    You will find the file here....
    C:\Documents and Settings\(Your Name)\Application Data\Autodesk\AutoCAD 2006\R16.2\enu\Support
    On second thoughts.....you may not find it there if you are using 2000.....you may find it here.....c:/program files/autocad2000/support
  6. #6
    Senior Member
    Using
    not applicable
    Join Date
    Nov 2006
    Location
    Melbourne Australia
    Posts
    181
    Default
    Hatch patterns are generally .PAT or .ZIP files containing one or more hatch patterns and are available from various sites. Links to hatch pattern collections (both free and commercial) are here:
    http://www.cadro.com.au/hatchkit/HatLinks.html
    AutoCAD and Revit pattern files are simple text files. AutoCAD expects patterns to be stored either in ACAD.PAT (and/or ACADISO.PAT) or in individual custom pattern files containing ONE pattern per file.
    Make sure:
    - there's a blank line at the end of the file.
    - no file line exceeds 80 characters in length
    - the file is named to match the hatch pattern inside the file (File "ZZZ.PAT" contains one pattern named ZZZ)
    - the pattern name is legal (consult your Help for details)
    - the file/pattern name does not match any "Predefined" pattern name
    - the file is in a directory on the Support File Search Path
    The custom hatch directory can be anywhere on your file system. More than one Support directory can be searched in the order set by Tools>Options>[Files]>[Support File Search Path]
    This allows you to leave the standard pattern files ACAD.PAT and ACADISO.PAT free to be overwritten as you reinstall or upgrade.
    The hatching control has tabs for "Predefined" and "Custom" patterns - "Predefined" patterns are then standard Autodesk patterns and "Custom" patterns are other than Autodesk.
    Whether hatch patterns are easy to make depends a lot on the pattern's complexity and your hatch editor. Notepad is fine for simple patterns as described in the Customization Guide found in AutoCAD's Help. More complex patterns can be a challenge and you could save time with a graphic editor such as HatchKit to inspect, create and edit hatch pattern files
    www.cadro.com.au/hatchit/
    Hugh Adamson
    Cadro Pty Ltd
    www.cadro.com.au
  7. #7
    Forum Newbie
    Using
    AutoCAD 2000
    Join Date
    Jul 2007
    Location
    Posts
    3
    Default
    Many thanks to you all for your help. The advice about copying the original and giving it a different name is what I tried and have been following all the other advice. It worked! I found some simple wood hatch patterns on :
    http://www.cadcorner.ca/hatch.php. if anyone else is interested. These are individual hatch types. They are shareware.
    Looks like I'm hatching away now!
  8. #8
    Full Member
    Using
    AutoCAD 2007
    Join Date
    Feb 2007
    Posts
    47
    Default
    You can try to create new custom hatches with some software.
    I found a free opensource software addon for autocad to create new custom hatches in autocad here.
    they say:
    If you need more than AutoCAD standard patterns for your hatch, this program is the solution! With MyHatch you can create hatches from scratch working inside AutoCAD, using lines and special tools to simulate arcs and circles. (abcautocad)
Similar Threads
  1. add additional hatch patterns
    By nailer341 in forum AutoCAD Beginners' Area
    Last Post: 2nd Aug 2008, 07:43 pm
  2. Using hatch patterns
    By edortizr6 in forum AutoCAD Beginners' Area
    Last Post: 16th Feb 2007, 04:42 pm
  3. hatch patterns
    By carrob26 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Nov 2006, 12:09 pm
  4. hatch patterns
    By bernard long in forum AutoCAD General
    Last Post: 23rd May 2006, 02:56 pm
  5. Hatch Patterns
    By daithicuc in forum AutoCAD Beginners' Area
    Last Post: 11th Dec 2003, 06:59 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
