Results 1 to 5 of 5
    Super Member
    Architectural DT 2007
    Dec 2002
    London
    1,087
    Default Maniuplating my materials
    Ive created some of my own materials in photoshop and imported them into AutoCAD.How do I change the scale of the pattern of my material?How do I rotate the pattern on my model?Ive looked at adjusting the bitmap scale in the render material dialogue box,but it gives me parculiar results,for instance my brick petterend wall will loose some of its pattern consistency and a few lines of bricks then join together.Anyway I'm pretty pleased that I can now add my own custom materials to the restricted AutoCAD library.
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,925
    Hypo,
    RMAT
    Material Library
    Import the material
    Close the library
    Modify button ( Upper Right )
    Adjust the bitmap ( Lower Right )
    At least in A2K....
    -David
    R12 (Dos) - A2K
    Super Member
    Dec 2002
    London
    1,087
    So I was looking at the right part.(same in 2004 to)Its just a question of changing the U & V scale and then previewing it until your reach the desired affect.How about rotating the material?If I rotate it say 90 degrees then how what would I need for the U & V setting in the offset?Am I looking at the right faeture to rotate my object?
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    1,925
    I did'nt think ACAD would let rorate a bitmap on material. Iwould have to play with it to find the affects of U & V. -David
    R12 (Dos) - A2K
  5. #5
    Super Member
    Dec 2002
    London
    1,087
    If you do find a way I'd be greatfull,only other option might be to rotate it in another program like photoshop before making the material available to cad
