you need to send the jpeg along with the dwg and re-set the file location using xref.
Version: 2007.
What is best way to import .jpg drawing?
I am asking this because I have following problem-Whe I use "insert-raster image" in order to import picture it works ok, but when I send drawing with it to some other computer, jpg picture is gone-only thing that remains of it is path on original computer written on drawing.
or ole the image in to the drawing
10100.co.uk ONC/HNC Building Studies :: FCAD32 :: AutoCAD 2009 :: Revit 2009 :: Architectural Technician A.C.I.A.T ::
you should just be able to type XREF and select import image from the drop down menu instead of import drawing, and voila
"God help you if I find any exploded hatches.... for every exploded hatch I find, I shall kill you."
or use the command "etransmit"
There are only 2 things which are infinite... the universe and the human stupidity.
"Life is not the amount of breath you take, it's the moments that take your breath away"
