If you do a (SSGET "x") will do a selection set of all enty on all layers
(ssget "X") creates a selection set of all entities in the drawing including those on layers that are frozen or off.
But i will not do allow to move LOCKED layer
hi, i made this to do the following;
this works fineCode:;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; 1) This routine will turn ALL layers (on/thaw/unlock) state. ;; 2) It will then select all the layers. ;; 3) Then move (NOT FLATTEN) everything to 0,0,0 coordinates ;; with a basepoint input from the user. ;; -->> by pryzmm 072007 !!! ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (DEFUN C:000 () (setvar "cmdecho" 0) (command "-layer" "u" "*" "t" "*" "on" "*" "" "") (setvar "osmode" 33) (princ "\nSelect base point->> hint (any end or intersection point):") (setq p1 (getpoint)) (command "move" "all" "" p1 "0,0,0" ) (setvar "osmode" 167) (setvar "cmdecho" 1) (prompt "......................done !!! ")(terpri) (princ)); end, but what i really want is something like the sequence below;
(defun c:000 ()
(mapped all the current layer state and save in memory)
(turn all the layers (on/thaw/unlock) if its find one that is
(off/freeze/locked))
(select all layers and move to 0,0,0 with a basepoint from user)
(change back all the layers to its previous state using the 1st line string of command or any other string));end of routine
any suggestion,,,gurus and coders alike ???
i use autocad 2006
devitg, could you exactly code that for me pls. im blurrr in this kind if codes, all i knew are those very basic ones,,,,plssssss...thanks
hi, thanks for that but could anyone pls. help on how exactly where to put this string in the above,,,,plsssss thanks guys in advance
