Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: 3D guitar body?
    Forum Newbie
    AutoCAD 2002
    Oct 2006
    4
    Default 3D guitar body?
    I want to create a 3D guitar body. a solid shape in 2D is no problem. However when you give it thickness there is another feature - a radius all the way round.
    How do you do that?
    Senior Member
    AutoCAD 2002
    Apr 2007
    North Carolina
    188
    Your info says you have LT, which does not have 3D capabilities
    Both acoustic and electric cases are of similar form
    Complex silhouette and mostly flat front and back, this makes the job easier
    I would do a simple 2D drawing of the top, region and extrude it to the thickness
    Now, most guitars do not have a razors edge for the sides so use the fillet command to round them over slightly
    Additional tips:
    Boost your isolines for a smoother drawing
    Save often, older versions are ... stubborn
    Forum Newbie
    AutoCAD 2002
    Oct 2006
    4
    Thanks for the reply. I just updated my profile. I have 2002 now so It really is 3D.
    I just tried experimenting with a cube, exploded so that its individual lines. I put a radius on the edges, hoping that it might extrude right the way down. Unfortunatly the rad doesn't carry all the way along the edge so it just rounds off the corners a bit.
    The second problem (for later) is that not all guitars are a slab with a radius. There are more complex recesses.
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
    Quote Originally Posted by pbassred View Post
    No need to explode before you fillet a 3d object. You can use the edge chain option for sequential tangent edges.
    For the recesses use subtract once you have made and located them.
  5. #5
    Forum Newbie
    AutoCAD 2002
    Oct 2006
    4
    have a look at this.
  6. #6
    Senior Member New2CADmike's Avatar
    AutoCAD 2000
    Jun 2006
    Central California
    198
    Like the green man said...don't explode your solid...you cant radius in the way you want...leave it solid and then radius the edges...now creating the shape that a guitar has on the back side,kind of rounded smooth shape...that is not easy to do,at least for me it isn't...
    Using ACAD 2000
  7. #7
    Forum Newbie
    AutoCAD 2009
    Oct 2008
    6
    Default my bass
    I used the fillet command to make a radius around the bass body
  8. #8
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    i would draw the shape you want in 2d using arcs and lines(or poly line). then extrude that. if you use individual lines you will either need to use the region command or pedit>join command. once you have your block you can create other features to subtract from this. for instance most guitars dont have a purely flat face or back so you can create an arced body to subtract from your guitar.
  9. #9
    Forum Newbie
    AutoCAD 2007
    Jun 2009
    8
    Reviving an old thread....I'm trying to do a guitar body too, but can't seen to get the Fillet command to work with the Chain option.
    How did you build your 3-d solid for the body before trying to fillet it?
    I drew the outline and extruded it.
  10. #10
    not applicable
    Sep 2008
    VA
    2,859
    the issue with your drawing is the way you created it. where is the start/end of your spline?
    Your solid will fillet if you enter a value of .125 or smaller for your radius. There is no need to Chain because you edge is 1 continous spline. The issue i think is where ever your start/end point is. Your best bet is to create your object with pline using lines/arc and fillet your corners to get the shape you want.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
  1. car body 3d drawing
    By TORVIC in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Aug 2006, 04:05 pm
  2. Has any body ever heard?
    By n8dgrt in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2005, 11:48 am
