viriato79 Posted August 6, 2007 Share Posted August 6, 2007 I have Autodesk Land Desktop and for many commands (for example raster imagem insert) the dialogue box is not appearing. I can only work with the command bar. It should be any option selected or something that I can´t find. How can I activate the dialogue boxes for the commands? Thanks Quote Link to comment Share on other sites More sharing options...
Norts Posted August 6, 2007 Share Posted August 6, 2007 Change your FILEDIA variable to 1 Quote Link to comment Share on other sites More sharing options...
Thaumaturge Posted August 6, 2007 Share Posted August 6, 2007 Generally in AutoCAD dialogue boxes are controlled by the system variable 'FILEDIA' which should be set to 1 to turn boxes on. Check this first. Quote Link to comment Share on other sites More sharing options...
viriato79 Posted August 6, 2007 Author Share Posted August 6, 2007 Thank you very much. Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted August 6, 2007 Share Posted August 6, 2007 so......viriato79..... Did Nort's answer work.......I would like to know so I can add this to the FAQ........ Quote Link to comment Share on other sites More sharing options...
viriato79 Posted October 21, 2008 Author Share Posted October 21, 2008 so......viriato79..... Did Nort's answer work.......I would like to know so I can add this to the FAQ........ Yes, It works. Thanks Quote Link to comment Share on other sites More sharing options...
