rename the file .dwg and voila!
how I can open .BAK file????
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
Rename it to any other name you want.....like yourname.dwg ....then open it like normal.....
Tiger, sometimes multitasking can be a real pain......ok....you are good at it......![]()
I have AUtocad Lt, I renamed the name X.bak to X.dwg , but i havent opened it yet!!!
<alert> add this to a FAQ Alan
Posting no more
are you sure you haven't renamed it to X.dwg.bak?? make sure you see the file name - under Tools and Alternatives...
(this part too Alan)
It is explained pretty good in the 2000i help files.
Solution
You can open BAK files in AutoCAD by first renaming the extension so that it has a DWG extension. These steps show how to do this using Windows Explorer.
- Using Windows Explorer, browse to the folder where the drawing (file with DWG extension) is located. Note: Steps 2 through 8 are only applicable if the drawing is not missing or misplaced.
- Highlight the file in Explorer.
- Right-click on the file name and select Rename from the pop-up menu.
- Using the arrow keys, move the cursor right after the period in the file name, then delete the DWG file extension.
- Enter OLD after the period. The drawing will now have OLD as its file extension. This saves the drawing in case it is needed later.
- Press ENTER to complete the change.
- When the Rename dialog box displays, choose Yes.
- In Explorer, browse to the drawing file with a BAK extension.
- Right-click the file name and select Rename from the pop-up menu.
- Using the arrow keys, move the cursor right after the period in the file name and replace the BAK file extension with DWG.
OK, thanks friends... I am working with german AUtocad Lt ,so I havent found where alternatives, I look over it at home at night !
slw210, I just copy the bak file to a different location, rename it with something temporary and change it's extension from there - anything to stop it overwriting the original file works though
bookmarked for FAQ![]()
Find your newbest friend
at
Rain Rescue
If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
