Results 1 to 9 of 9
    Junior Member sumski's Avatar
    AutoCAD 2002
    Aug 2007
    Croatia
    12
    Default .dbf in exported ESRI Shape file
    Hy, I"m working in AutoCad 6.
    My map contains points with x and y coodrinates, around them are circles.
    I want to export them in shape file (which creates .dbf, .shp, .shx files), but .dbf doesn"t contain useful database (it writes: name of file_ID, and nothing else), I need number of point and its coordinates (x and y).
    How can I create .dbf with that 3 datas- number of point, x coordinate, y coordinate?
    Thanks for all helpful answers
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,199
    I don't think AutoCAD will do the .dbf. Is this for ArcGis or something? Are you using 3DMAP or something?
    AutoCAD 2002
    Aug 2007
    Croatia
    12
    Yes, its for GIS (precisley for ArcPad)
    and AutoCad can create .dbf, I have found the way how to get coordinates few minutes ago, but they are not correct
    Full Member
    AutoCAD 2007
    Feb 2007
    47
    Default AutoCAD can't Map can
    Maybe you're using Autodesk MAP 6 and not AutoCAD 6.
    Go to MAP menu, Tools submenu and Export menu entry
    Choose Shape file from file type (shp is the extension).
    If you need to import points, check this useful tool for importing points in autocad
  5. #5
    AutoCAD 2002
    Aug 2007
    Croatia
    12
    Thats right, I"m using Autodesk MAP 6, my mistake, sorry..
    I solved the problem;
    Durring exporting shape file Export window is displayed, on 2nd tab (DATA) I choosed datas for .dbf file, in my case that would be ID_number, x coordinate and y coordinate, and thats it!!!
    Final product is shape file with related data base (.dbf) wich you can open in MS Access, Excel... and arrange geted datas
  6. #6
    AutoCAD 2002
    Aug 2007
    Croatia
    12
    Quote Originally Posted by mtrasi View Post
    Thanks for advice and useful link!!!!
  7. #7
    Forum Newbie
    Revit 2009
    Feb 2009
    2
    Is is possible to import .shp, .shx & .dbf files from ArcGIS into AutoCAD 08?
  8. #8
    Full Member
    AutoCAD 2007
    Feb 2007
    47
    Smile Addons to import points and SHP esri in AutoCAD (from Italy)
    Yes, if you have only AutoCAD you need an addon like ImportPoints or ImportShapes from ABC AutoCAD.
    Try the Downloads for AutoCADpage It's an italian site, but you can find also an english page for AutoCAD addons
  9. #9
    Forum Newbie
    Revit 2009
    Feb 2009
    2
    Thank you...I'll try it!
  1. Select Shape File
    By djgraham20354 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jan 2007, 08:26 pm
  2. DWG TrueViewer - select shape file????????
    By tfranke@sodeep.com in forum AutoCAD Drawing Management & Output
    Last Post: 7th Apr 2006, 01:19 pm
  3. word document exported into autocad2004
    By cadclutze in forum AutoCAD General
    Last Post: 31st Jan 2006, 03:14 pm
  4. "Select shape file"
    By bbfirebird in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jan 2006, 06:14 pm
  5. autocad exported to bryce
    By william pearson in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th May 2005, 05:44 pm
