Results 1 to 2 of 2
    Senior Member
    AutoCAD 2008
    Aug 2007
    104
    Default How do I auto-align text when rotating a block?
    Ok so I'm revamping all of our blocks a work and I need some help with a few of them. I need to find a way to have the text (or attribute) always showng at 0 degrees when the block is at 0, 90, 180 or 270 degrees. To further complicate things, the text (or attribute) needs to be aligned with the block at any non-standard angle, and depending on the angle, the text will have to be facing a different way. here's a picture to clarify:
    Is this possible? Thanks.
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Look into using Dynamic Blocks, Rotate and Lookup Parameters/Actions should do what you want to accomplish.
    Here is a site with some tutorials on dynamic blocks:
    http://www.dgcad.com/Acad2006-DynamicBlocks.htm
  1. Align a block to other objects (2006 and later)
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 14th Jan 2008, 05:32 am
  2. text align command
    By brassworks in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jun 2007, 05:15 pm
  3. How do I align text within a block when rotating a block
    By troutspinner in forum AutoCAD General
    Last Post: 15th Mar 2007, 01:23 am
  4. Replies: 0
    Last Post: 6th Sep 2006, 09:19 am
  5. align text along polyline
    By wisper in forum AutoCAD General
    Last Post: 2nd May 2006, 12:34 pm
