Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 59
    Full Member jfruscione's Avatar
    AutoCAD 2008
    Oct 2006
    Franklin, TN
    32
    Default AutoCAD to Microstation help
    I am using AutoCAD 2008.... The problem is that when I send efiles to a company that uses Microstation they can't open the files or convert from AutoCAD to Microstation, they used to have no problem until I upgraded to 2008. Does anyone else have this problem or know of something I or they might be doing wrong? Need help fast.....
    I have converted the drawings down to ACAD 2000 and this used to work but does not anymore.....
    Blah!
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    Dwg should work, I think the problem might be with the Microstation user. Have you tried sending them as DGN?
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,635
    Well the Microstation user can open DWG files. Last few versions of Microstation can open DWG files. Saving down to 2000 or even 2004 should work. As far as I know only AutoCAD Map or maybe LDD can export/save out to DGN files. McSwain or Alan can maybe check on this part as I don't have either version.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    Quote Originally Posted by f700es View Post
    AutoCAD 2008 can export DGN. Not sure what version they started that with.
    Look under the File>export and where it says "Files of type:"
  5. #5
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,635
    Ah, then that's new to 2008 then as my 2007 cannot. Looks like he has the solution then. Thanks for the pick-up SLW
  6. #6
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    I meant the individual using Microstation. I already stated dwg should work. Which if this is the case he may not be able to open a DGN file either.
    He has 2008, therefore he should be able to send a DGN, Microstation can open DGN as well.
  7. #7
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    I'll check it at work tomorrow......
    One thing to understand here.....Autodesk do not worry about, or comply with other formats....and don't care.....marketing strategy.....other software mobs have to comply with Autodesk requirements....and most of them have given up....because updates to Autodesk are happening so more often......they can't keep up......
  8. #8
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,635
    Quote Originally Posted by Alan Cullen View Post
    Well not to wave the AutoCAD flag too hard but it is their format and technology. They do sell a DWG Development Kit and I think it's up to outside people if they want to pay for it or not. Updates come once about every year. No big difference to anybody else. The good thing is that we are seeing a 3 year cycle on DWG format change. Which is good. It's pretty good that 2004 can open up to 2006 drawings
  9. #9
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,635
    Quote Originally Posted by SLW210 View Post
    Well having used Microstation way back when (on DOS) ...DGN is a Microstation format. Unless it has changed.
  10. #10
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    I have been in your shoes for awhile myself f700, we used 2000i up till a couple of weeks ago. I was constantly trying to figure out how people were doing things that kept telling me "unkown command".
  1. AutoCAD & Microstation
    By Chronos69 in forum AutoCAD General
    Last Post: 26th May 2010, 02:58 pm
  2. AutoCAD to Microstation.
    By skipsophrenic in forum AutoCAD General
    Last Post: 3rd May 2009, 11:25 pm
  3. Microstation and Autocad
    By Scott44 in forum AutoCAD General
    Last Post: 20th Feb 2009, 07:58 pm
  4. microstation vs autocad
    By dadamczyk in forum AutoCAD Beginners' Area
    Last Post: 11th Dec 2008, 09:55 pm
  5. Microstation to Autocad
    By Martini in forum AutoCAD General
    Last Post: 24th Sep 2008, 02:08 pm
