Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 59 of 59
  1. #51
    Full Member jfruscione's Avatar
    AutoCAD 2008
    Oct 2006
    Franklin, TN
    32
    Quote Originally Posted by SLW210 View Post
    I thought you were using eTransmit to send them.
    Etransmit uses the default zip program and that was winzip......At least I think that is how it works, right?
    Blah!
  2. #52
    AutoCAD 2008
    Oct 2006
    Franklin, TN
    32
    Were this drawings originally created on another program?
    They were created in AutoCAD or Microstation depending on which problem below you are referring to.
    Blah!
  3. #53
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Yes
    Try zipping them without using eTransmit and send them.
  4. #54
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Have you tried running a recovery on the drawings?
  5. #55
    AutoCAD 2008
    Oct 2006
    Franklin, TN
    32
    Did not work, either did zipping them myself without etransmit..... This is getting really bad here at work..... I am now worried about keeping my job.....No joke!
    Blah!
  6. #56
    AutoCAD 2008
    Oct 2006
    Franklin, TN
    32
    I have fixed the problem with the etransmit.....I just needed to modify the etransmittal to transmit drawings in AutoCAD 2000 format..... I thought that I was doing that by saving the drawing down to AutoCAD 2000 but apparently it didn't work like that.....So that is fixed, I think this will fix the microstation problem also, I will find out later today.
    Blah!
  7. #57
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Cheers! Hopefully that will fix it. Where in ePublish did you find this?
  8. #58
    AutoCAD 2008
    Oct 2006
    Franklin, TN
    32
    Never used epublish.....
    etransmit-create transmittal-transmittal Setups-modify or create new-file format-AutoCAD 2000/LT2000-OK
    This seems to change where your etransmittal is saved to, so you have to browse to save it in the correct folder unless you use the same folder for all transmittals, I use the folder my drawings are in to save the transmittal. There must be a way to change that but I have not figured it out yet.
    Blah!
  9. #59
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    As I was reading the updates in Service Pack 1 for 2008, I found this. Perhaps this was your problem.
    E-Transmit
    • AutoCAD 2000 and Release 14 file formats are preserved while using ETRANSMIT with the "Keep existing drawing file formats" setting enabled
  1. AutoCAD & Microstation
    By Chronos69 in forum AutoCAD General
    Last Post: 26th May 2010, 02:58 pm
  2. AutoCAD to Microstation.
    By skipsophrenic in forum AutoCAD General
    Last Post: 3rd May 2009, 11:25 pm
  3. Microstation and Autocad
    By Scott44 in forum AutoCAD General
    Last Post: 20th Feb 2009, 07:58 pm
  4. microstation vs autocad
    By dadamczyk in forum AutoCAD Beginners' Area
    Last Post: 11th Dec 2008, 09:55 pm
  5. Microstation to Autocad
    By Martini in forum AutoCAD General
    Last Post: 24th Sep 2008, 02:08 pm
