Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Senior Member
    AutoCAD 2004
    Apr 2006
    236
    Default Draw Order not working correctly
    It seems as though my draw order is 'locked'. The command is recognized; but it doesn't seem to work properly.
    I essentially have two lines, drawn right on top of eachother; I go to get the one underneath and bring to front/send to front, or send the top line to the back, etc. and nothing changes at all.
    I've found a way to get what I need done completed so I don't need a solution, but is there some variable I'm not aware of that affects the use of draw order?
    Justin J. F. RamireZ - Drafter Extraordinaire
    Bryan/College Station, Tx
    REVIT MEP 2009, CAD MEP 2009, CAD LT '00 & '04, CAD 04
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,547
    Look into SORTENTS I use 119 -David
    R12 (Dos) - A2K
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    have you done a purge and regen - just coz AutoCAD is strange like that sometimes
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    Senior Member
    AutoCAD 2004
    Apr 2006
    236
    Purging and the SORTENTS didn't help.
    However using DRAWORDER, then referencing the object I needed to get this one line under worked. The Draw Order toolbar doesn't seem to help but the written command does
  5. #5
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    it isn't a PICKFIRST problem is it?
    what's your PICKFIRST set to?
  6. #6
    Senior Member
    AutoCAD 2004
    Apr 2006
    236
    Quote Originally Posted by Strix View Post
    Rah! this is a handy thing to know about, but it didn't help when alternating between 0 and 1.
    I think this may have just been a freak event; I just finished the drawing, went to open another,
    "Command "Open" Unknown"
    "Command "Close" Unkown"
    "Command F***YouCAD" Unknown"
    -qsave
    -quit
  7. #7
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    make sure you leave PICKFIRST set to 1 though
  8. #8
    Senior Member
    AutoCAD 2004
    Apr 2006
    236
    Yup. Turns out it was just a temp. glitch. I closed out, re-opened it, and everything worked fine.
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    Quote Originally Posted by slimjramirez View Post
    -qsave
    -quit
    I should set that command up to give a big "F***U2" on the screen.
  10. #10
    Forum Newbie
    AutoCAD 2004
    Aug 2007
    1
    Default Draworder issue
    Try the variable:
    treedepth
    if it is set to 0, it will give you the problem you are describing.
    set it to 3020.
    Type: Integer
    Saved in: Drawing
    Initial value: 3020
    Specifies the maximum depth, that is, the number of times the tree-structured spatial index can divide into branches.
    0 Suppresses the spatial index entirely, eliminating the performance improvements it provides in working with large drawings. This setting assures that objects are always processed in database order, making it unnecessary ever to set SORTENTS.
    >0 Turns on spatial indexing. An integer of up to five digits is valid. The first three digits refer to model space, and the remaining two digits refer to paper space.
    <0 Treats model space objects as 2D (Z coordinates are ignored), as is always the case with paper space objects. Such a setting is appropriate for 2D drawings and makes more efficient use of memory without loss of performance.
    Note You cannot use TREEDEPTH transparently.
  1. Annoying Draw Order.
    By Cadastrophic in forum AutoCAD Drawing Management & Output
    Last Post: 17th May 2013, 02:30 pm
  2. Draw order
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 31st Jan 2012, 08:07 pm
  3. Draw order
    Last Post: 3rd Aug 2007, 09:21 pm
  4. Selection and Draw order
    By viriato79 in forum AutoCAD General
    Last Post: 15th Jul 2007, 06:37 pm
  5. DRAW ORDER-WIPEOUT-XREF
    By J-LYLE in forum AutoCAD Drawing Management & Output
    Last Post: 9th Sep 2005, 09:20 pm
