Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Forum Newbie
    Architecture 2010
    Apr 2010
    4
    Default Best answer
    I had this problem today and found this answer and it worked for me. Great job, CADMANGOD.
    Quote Originally Posted by cadmangod View Post
    Try the variable:
    treedepth
    if it is set to 0, it will give you the problem you are describing.
    set it to 3020.
    Type: Integer
    Saved in: Drawing
    Initial value: 3020
    Specifies the maximum depth, that is, the number of times the tree-structured spatial index can divide into branches.
    0 Suppresses the spatial index entirely, eliminating the performance improvements it provides in working with large drawings. This setting assures that objects are always processed in database order, making it unnecessary ever to set SORTENTS.
    >0 Turns on spatial indexing. An integer of up to five digits is valid. The first three digits refer to model space, and the remaining two digits refer to paper space.
    <0 Treats model space objects as 2D (Z coordinates are ignored), as is always the case with paper space objects. Such a setting is appropriate for 2D drawings and makes more efficient use of memory without loss of performance.
    Note You cannot use TREEDEPTH transparently.
  2. #12
    Forum Newbie
    utor's Computer Details
    Win 10
    AutoCAD 2018
    Apr 2013
    7
    Quote Originally Posted by bdeshawn View Post
    I completly agree, this finally solved my display problem with TEXTTOFRONT not working properly.
    Now that is selt the TREEDEPTH variable to 32767 (max. value) everything is working fine.
    Thanks a lot!
    utor
  3. #13
    Senior Member SAFeSTeR's Avatar
    SAFeSTeR's Computer Details
    W7 64-bit
    Intel Xeon @ 3.20Ghz
    12 GB
    Utilities
    SAFeSTeR's Discipline Details
    CAD Technician
    Utilities
    Water main replacement schemes.
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    Sometimes when I change the draw order of objects the results don't show until after a regen.
  4. #14
    Senior Member TheCADnoob's Avatar
    See details...
    TheCADnoob's Discipline Details
    Drafter
    See details below.
    Got a degree in rocket surgery that I cant use so I'm doing CAD work. I literally have my hands on all disciplines and am loving every minute of it, unfortunately by not specializing I believe I have found the Zen Noob. Jack of all master of none.
    AutoCAD 2013
    Mar 2015
    246
    The visual style will also affect draw order. I believe Draw order only works in the traditional 2d visual style (or at least thats what i was told)
    IT - "I would be glad to help you, but first I need you to make sure you computer is plugged in."
    CADnoob - "I'm Not that dumb"
    IT - "I'm sure you are not, but could you just humor me?"
    CADnoob - "Ok Ok... let see.. Crap! Never mind, thanks for your help."
  5. #15
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    The default for TREEDEPTH is 3020, so if you have something else it has been altered.
  6. #16
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    Quote Originally Posted by SAFeSTeR View Post
    That is normal.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #17
    Forum Newbie
    AutoCAD 2007
    Aug 2016
    1
    Default Draw order
    Quote Originally Posted by Strix View Post
    have you done a purge and regen - just coz AutoCAD is strange like that sometimes
    Yeay...it works after purge and regen. Thanks man
  1. Annoying Draw Order.
    By Cadastrophic in forum AutoCAD Drawing Management & Output
    Last Post: 17th May 2013, 02:30 pm
  2. Draw order
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 31st Jan 2012, 08:07 pm
  3. Draw order
    Last Post: 3rd Aug 2007, 09:21 pm
  4. Selection and Draw order
    By viriato79 in forum AutoCAD General
    Last Post: 15th Jul 2007, 06:37 pm
  5. DRAW ORDER-WIPEOUT-XREF
    By J-LYLE in forum AutoCAD Drawing Management & Output
    Last Post: 9th Sep 2005, 09:20 pm
