Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Senior Member JaketheMan's Avatar
    JaketheMan's Computer Details
    Windows XP
    1 GB
    CTX Ultra Screen
    AutoCAD 2008
    May 2007
    Asheville, NC / Bristol, TN
    160
    Default How to show scale
    I have my product scaled at 3"-1' and I want to show how it's being scaled automattically with text on my paper space drawing. How do I do that?
    "Think it,
    Design it,
    Build it."
    www.Microvellum.com
    The World's #1 AutoCAD Based Manufacturing Software.
    Software Solutions for the Woodworking Industry.
    Senior Member
    jammie's Computer Details
    Ubuntu / XP / W8
    Civil
    jammie's Discipline Details
    Design Technician
    Civil
    AutoCAD 2012
    May 2006
    Ireland
    299
    Hey Jaketheman,
    A field can be used to track and display a viewport scale.
    Start the relevant text command and cick Insert Field to add a field
    Choose Object as Field Category and select the required viewport as Object type. Under property choose custom scale and select the required format.
    AutoCAD inserts a field into the text string that checks the viewport’s scale. The field displays the current value and updates whenever it changes
    Hope this is of some help,
    Jammie
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    and as a cross check that it hasn't been plotted on the wrong size paper and naffed the scale up, do you turn the plotstamp on and select scale to show in that too?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    Windows XP
    1 GB
    CTX Ultra Screen
    AutoCAD 2008
    May 2007
    160
    No Strix I haven't known how to do that, but that's I believe exactly what I'm trying to do. Jamiee thanks though for the answer because that does help a lot. But as far as a plotstamp goes, that sounds like its exactly what I'm looking for. How do I do that?
    "Think it,
    Design it,
    Build it."
    www.Microvellum.com
  5. #5
    Windows XP
    1 GB
    CTX Ultra Screen
    AutoCAD 2008
    May 2007
    160
    Also I haven't been able to get my text formatting screen to show, only Text. Go figures, i'll try playing around with pallettes and such but it's still not showing up
    "Think it,
    Design it,
    Build it."
    www.Microvellum.com
  6. #6
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    For the plot stamp.....Plot.... in the plot pop-up check the plot stamp then the plot stamp editor button will be available...click the editor button...in the Plot stamp pop-up make sure Plot Scale is checked.
  7. #7
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    For the text editor go to Options>Files and make sure it is set to "Internal", or what ever text editing program you want like Word, Excel or NotePad. Just use the browse option to pick another program. You can also use MTEXTED to set it to Internal or what ever.
  8. #8
    Windows XP
    1 GB
    CTX Ultra Screen
    AutoCAD 2008
    May 2007
    160
    I found where I can use Text Formatting, however when I try to plot I do not get any "Plot Options" on my plotting screen. Maybe I'm looking in the wrong place. Here is a picture of what appears when I goto File> Plot
    "Think it,
    Design it,
    Build it."
    www.Microvellum.com
  9. #9
    Windows XP
    1 GB
    CTX Ultra Screen
    AutoCAD 2008
    May 2007
    160
    Perhaps that feature is not available on 2007? It appears you're window seems to be a little more up to date, your buttons are smooth mine are squared :-(
    "Think it,
    Design it,
    Build it."
    www.Microvellum.com
  10. #10
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    Click that little arrow in the lower right corner.
  1. understanding drawing scale and scale factor
    By flyingal in forum AutoCAD Beginners' Area
    Last Post: 11th Jul 2012, 06:30 pm
  2. Scaling linetype scale with SCALE command?
    By SpeedDemon in forum AutoCAD General
    Last Post: 23rd Jul 2007, 03:28 pm
  3. LIghts that do not show up
    By ROCKHOPPER1 in forum AutoCAD General
    Last Post: 1st Feb 2007, 10:18 pm
  4. Slide Show
    By RODDY1 in forum AutoCAD Drawing Management & Output
    Last Post: 11th May 2005, 02:01 pm
  5. Materials does not show
    By fyrekrig in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Feb 2005, 09:03 am
