Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2002
    Aug 2007
    2
    Default Text prints only outline
    Ok I am using ACAD2002... Previously I was able to print to what ever printer I wanted and my text in my template in paper space would print out solid and black....Earlier today I attempted to paste part of a spread sheet into my acad. It did not work, but since then whenever I try to print my text is outlined instead of solid. Kinda hard to see and read. Please help me...
    Thanks,
    Jmzcustomz@sbcglobal.net
    Super Member
    AutoCAD not applicable
    Jul 2007
    639
    Try your TEXTFILL variable it should be set to 1 for solid filled text,
    btw - welcome
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Quote Originally Posted by jmzcustomz View Post
    Thanks,
    Many possible reasons for this issue.
    First check the variables FILLMODE and TEXTFILL; they should be both set to 1.
    Then check that the visual style is not set to hidden but rather to 2dwireframe (_vscurrent > 2)
    This problem happen even if the viewport in paperspace has the shade plot option set to hidden instead of "as displayed" but this should affect only the text in model space showed in your viewport.
    Hope one of this suggestions solves your problem
    HAVE A NICE DAY
    Forum Newbie
    AutoCAD 2002
    Aug 2007
    2
    Thanks soooo friggin much. I knew it was something simple and I am just too tired to figure it out. Thanks ps_port...
    Not to change subjects but are there many users here that use Accurender?
  5. #5
    Super Member
    Jul 2007
    639
    Haven't used Accurender, do most of my renders through plain acad or maybe a little 3DMax, - some photoshop touch ups, but I'm sure someone here will.
  1. text prints out bold when its NOT bold
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 24th Feb 2012, 01:41 pm
  2. Prints Rotated
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Feb 2007, 11:31 am
  3. Text Outline?
    By PeteUK in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2007, 06:21 pm
  4. Arial text printing to PDF as outline
    By Kristen in forum AutoCAD Drawing Management & Output
    Last Post: 10th Nov 2006, 11:28 am
  5. 3D models into part prints
    By Bigbear57 in forum AutoCAD Drawing Management & Output
    Last Post: 10th Nov 2004, 11:57 am
