Results 1 to 2 of 2
    RSS Feed Posting Robot CAD-e-Corner's Avatar
    Sep 2006
    49
    RSS Feed Editing Attributes
    There are many ways to edit Block Attributes. The standard method is to simply double-click the Attribute to invoke the Enhanced Attribute Editor.
    Use the Attribute tab to change the value of an Attribute. Use the Text Options and Properties tabs to change: Text style, Justification, Height, Width Factor, Oblique Angle, Layer, Color, Lineweight, etc.
    So how does one edit more than one Attribute at a time? You can select the Blocks and use the Properties palette to modify values of common Attributes. Consider the three insertions of the two Blocks shown here.
    Both Blocks have an Attribute with a tag name SEC. When three of the insertions are selected, the common Attribute Tags are available to edit in the Properties palette. Change the value as desired.Global editing of Attribute values can still be accomplished with the old, tried and true, -ATTEDIT command. Don't forget the dash; ATTEDIT alone invokes the older (non-Enhanced) Attribute Editor dialog. The -ATTEDIT command exists virtually unchanged since the very early days of AutoCAD, so the syntax is a bit clunky, but it will allow you to replace all or part of an existing Attribute value on all or selected Blocks. -ATTEDIT will also edit other Attribute properties beside value, but one by one, not on a global basis.
    There's also an Autodesk supplied Express Tool, GATTE, that globally changes the selected Attributes' value only.
    More...
    CAD-e-Corner - Blog by Ward Romberger
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    And in AutoCAD 2008 you can use CUI to change double clicking into the faster DDATTE
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
  1. A question about editing block attributes
    By alijahed in forum AutoCAD General
    Last Post: 9th May 2007, 06:02 am
  2. CUI Editing
    By thalon in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Apr 2007, 10:39 pm
  3. need help...xref's not editing
    By hina in forum AutoCAD General
    Last Post: 14th Jul 2006, 06:54 am
  4. CTB Editing
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 3rd May 2006, 03:54 pm
  5. editing blocks
    By lorenzo in forum AutoCAD Beginners' Area
    Last Post: 10th Oct 2002, 08:35 pm
