Here is an example, how can I fillet the corner ?
Thanks !!!
I want to draw 2 tubes (circle tubes) and they intersect with each other, but don't know how to draw the intersection plane, could you help me ways to do it !
Thank you very much![]()
Thanks !!!
I'm not sure if it's exactly what you're looking for....
See DWG.
Przemo
You could also draw first the axis of 2 pipes, then you use the command fillet to join them with the radius you want.
After you join all into a polyline, then you draw 2 circle (inside and outsid diameter of your pipe) and then command sweep, you choose the 2 circles, enter, you select the polyline and enter again.
Hope is clear enough![]()
HAVE A NICE DAY
Oh, my method is create a sphere but your way is more professional !!!
Thank you![]()
Depending on what type of intersection Im going for, I either use the sphere method or slice the cyls at 1/2 the intersection angle
If you are working in 3D, looks like it in the screenshot.
Extrude along a path, the path being the line filleted.
Nick
http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
http://s240.photobucket.com/albums/ff241/dyNick_Scots/
http://designgraphicsshowcase.blogspot.com/
High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
Home - AMD 2.1GHZ - 512Ram, 64 Video,
Laptop Inventor 7, Autocad 2004, Corel 11
yeah, but I found if you extrude a cylinder along the path, the cylinder will stretch to the path but not have the path as a symmetric axis![]()
