What you have is a loft and from what I was reading, you cannot flat pattern a loft
Read this:
http://discussion.autodesk.com/adskc...sageID=3925548
See the attached part file.. and please help me..
How can I get the flat pattern of this model ?
Read this:
USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
If in doubt scale and don't ask!
I will have a look for you, however sheet metal features are not something I have played with(very little) I never use the sheet metal side of Inventor so I may not be the best person to answer, but like I said I will have a look for you.![]()
Can you not model the part using the sheet metal.itp what way the sheet metal flat pattern will work out the calc easy?
