Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 50
  1. #11
    Full Member JimB's Avatar
    JimB's Computer Details
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    Ive stripped everything I've got one single line and it is still doing it.
    I've purged the hole file deleted anything and every thing and still 375k which is still 125 to big... sorry don't know what else to delete
  2. #12
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Just try with the one line and one dimension that shows us what you are talking about. And save it back to Acad 2004 (obviously to a different name).
    Or block that aspect out. That should reduce the file size.
  3. #13
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    Default FILE Attached
    OK thanks
    the saving 2004 did wonders !
    Attached
  4. #14
    Map 3D 2009
    Jun 2006
    4,181
    I only got one vertical line (coloured red). want to try again?
    You also have something in the far corners of the drawing universe. Try ZOOM E and you will see what I mean.
  5. #15
    Map 3D 2009
    Jun 2006
    4,181
    Okay, I think I have your problem.
    Go to DDIM and Unclick Lines->Fixed length extension lines. Then have a good play around with all the settings. If you change the tab in the DDIM dialogue box, the settings you change will update in the window to the right, so you can see what you have done. Play with all of them untill the window displays what you want. Then "set current" and close.
  6. #16
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    Sorry just got back one of the kids wanted me
    will try what you have suggested & let you know how I get on
    Thanks Alan
  7. #17
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    Alan repeated what you suggested ..
    I've done that previously with out result and again now.
    Have a go your self 'unticking the fixed extension lines'
    then try and reset teh thing to fixed at 200.
    When you do this it works fine dimensioning in teh middle of nowhere but if dim of the line it doesn't work...
    See the problem?
  8. #18
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    There is some thing else that is the problem and it is not with the domension manager becasue I've just tryed the same thing with the default dim.
    There is something within the file it self that has to be changed I have no idea what it is and I don't know what i've changed to being this problem about?
  9. #19
    Map 3D 2009
    Jun 2006
    4,181
    Don't reset it, when you have it in the view window, accept it.
    I just did random ho dim anywhere, and it works. As I said, play with the settings in ddim, and when the window looks like what you want, accept it.
  10. #20
    Map 3D 2009
    Jun 2006
    4,181
    Set YOUR dimstyle as current. Forget about the other one. The dimstyle you muck around with to get how you want, set THAT one as current.
  1. No more mystery plots
    By daaper in forum AutoCAD General
    Last Post: 5th Jun 2006, 03:27 pm
  2. Dimension Text Mystery
    By erc3 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jan 2006, 06:08 pm
  3. Line Extension Add-on
    By scotty in forum AutoCAD Drawing Management & Output
    Last Post: 1st May 2005, 03:39 am
  4. Extension line problems
    By clanda in forum AutoCAD Beginners' Area
    Last Post: 2nd Apr 2004, 03:05 pm
  5. mystery mtext problem in r14
    By ian_foster in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2003, 11:32 pm
