Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 50
  1. #21
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Tell me what happens in your drawing when you zoom extents.
  2. #22
    Full Member JimB's Avatar
    JimB's Computer Details
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    blows right out and can't see the line
  3. #23
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    Another suggestion:
    In your problem drawing,
    make one line,
    add some dimensions,
    select a dimension and rightclick to set another dimstyle.
    Select the line and dimensions,
    use W for WBLOCK to safe the selection as a new file.
    And post it
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
  4. #24
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    Zome extents zooms rightout & can't see the line, far to small
  5. #25
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    new block attached
  6. #26
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    Allan the problem has the following reprocussions.
    That red line is taken from a drawing with thousands of other lines blocks etc.
    any thing I snap to in that drawing the dim line wont provide an extension line (which I want at 200)
    Now there are 4 other drawings like that have very similar designs I have no problem within them doing what we have been trying to do.
    But only that line and all the details in that drawing. I've even imported the drawing into those that don't have the dimension extension line problem.
    In that situation the dim works fine on anything that existed originally in that drawing BUT if I dim of anything from the imported drawing (which includes that particular red line ... it wont work ?
    It doesn't make sense but that is whats happening.
  7. #27
    Map 3D 2009
    Jun 2006
    4,181
    Raggi_Thor, the original post from JimB is fine. Work on that.
    JimB, zoom extents, then zoom out a bit more. do a list of the extended area away from the main drawing area, you will find there are text entities there. I suggest you delete them. You'll have to do it twice, once on the bottom of your drawing, and once on the left side of your drawing. You should get 12 entities all up.
  8. #28
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    If you dimension off that red line can you get a 200 extension line ?
    Or any nominated figure for a 'resstricted length' extension line ?
    Are you getting a result?
  9. #29
    Map 3D 2009
    Jun 2006
    4,181
    Forget the 200. That is your problem area. You do not understand the settings for dimension style. Trying to keep that 200 there is your problem. Maybe clean up those text entities in no-mans land may help. The other thing is to keep an eye on what dimstyle is current when you bring other drawings in.
    Get back to me, this has me intrigued.
  10. #30
    DEL, XPS, M1530
    4 gig
    AutoCAD 2012
    Sep 2007
    Adelaide, Australia
    71
    yep got them
  1. No more mystery plots
    By daaper in forum AutoCAD General
    Last Post: 5th Jun 2006, 03:27 pm
  2. Dimension Text Mystery
    By erc3 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jan 2006, 06:08 pm
  3. Line Extension Add-on
    By scotty in forum AutoCAD Drawing Management & Output
    Last Post: 1st May 2005, 03:39 am
  4. Extension line problems
    By clanda in forum AutoCAD Beginners' Area
    Last Post: 2nd Apr 2004, 03:05 pm
  5. mystery mtext problem in r14
    By ian_foster in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2003, 11:32 pm
