Results 1 to 7 of 7
    Junior Member
    AutoCAD 2004
    Jul 2007
    Sydney Australia.
    10
    Default Arc - Start Center Angle
    Hi,
    I am working through "Autocad-No Experience Required" book and I am drawing arcs for door openings.
    The book sais to use Arc,Start Centre,Angle.
    I have done 3 OK but I cant get the arc in the right place on the 4th,even though I am using the same detail. IE ( Start = Door jamb,Centre = Hinge point,angle = 90 Deg)
    Any suggestions.
    Thanks
    Greg
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    so how is it coming out if it's going wrong?
    (and does the book really spell 'experience' like that? )
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    Junior Member
    AutoCAD 2004
    Jul 2007
    Sydney Australia.
    10
    The arc is coming out below the door opening ,so If I mirrored it it,it would be OK.But I am not sure what I am doing wrong.
    (By the way,Its not my spelling,its my typing!)
    Thanks
    Greg
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,881
    Maybe the angle needs to be -90.
  5. #5
    Junior Member
    AutoCAD 2004
    Jul 2007
    Sydney Australia.
    10
    Quote Originally Posted by SLW210 View Post
    Too easy,!! (When you know) Thanks very much for your help
    Regards
    Greg
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,076
    One tip, when you are doing these door arcs, is that just before you enter the angle, move the crosshairs to see which way AutoCAD is going to draw the arc. If the arc is the correct side of the opening, then the angle is 90, but if it is the wrong side of the opening, then the angle is -90
  7. #7
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,881
    You can also set ANGDIR to 1 for clockwise, the default is 0 for counterclockwise.
  1. Replies: 13
    Last Post: 14th Nov 2011, 02:46 pm
  2. 1st angle/3rd angle projection
    By Lazer in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Jun 2011, 02:09 pm
  3. Where Do I Start?
    By parkpointer in forum AutoCAD Beginners' Area
    Last Post: 1st Jan 2007, 10:42 pm
  4. Where to start?
    By Random1 in forum Autodesk Inventor
    Last Post: 29th Mar 2006, 07:36 pm
