Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2006
    Sep 2007
    now in Hanoi, soon back in Switzerland
    3
    Default osnap tracking: second tracking line?
    Good moring!
    I'm having problems with the exercice of the OSNAP tutorial.
    The aim is to pick the center point of a rectancle by using osnap tracking and two times the MID osnap to get the middle of the left side of the rectangle and the middle of the bottom side of the rectangle.
    My problem is, that I get only one tracking line instead of two as shown in the tutorial. So I'm not able to pick the center of the rectancle.
    Does somebody know the reason for this?
    Senior Member the ber's Avatar
    AutoCAD LT 2013
    Nov 2006
    Germany
    187
    when you have selected the midpoint of the first line, you should see the dotted line when you move the cursor away from this midpoint. when you now move the cursor over to the other line to get its midpoint, there should be a little cross left behind at the midpoint of the first line. when you get the dotted line from the second midpoint and move it towards the center, you should then see both dotted lines when they line up.
    if however there is another line or something near the center of the rectangle, then a different object snap might try to grab this other line. in this case you might lose the pair of dotted lines.
    Forum Newbie
    AutoCAD 2006
    Sep 2007
    3
    yes, I'm getting the two small crosses displayed at the same time, but I only can get one tracking line. When I'm near the center, I can switch from one trackin line to the other, but I cannot get both at the same time.
    by the way, what lake/sea can I see in the background of your picture?
    AutoCAD LT 2013
    Nov 2006
    Germany
    187
    sorry, but i couldn't duplicate your problem. could it have something to do with your snap settings, so that the cursor cannot land on the intersection of the two lines? i think the key to try to check this is F9 (not sure because my software is german). or it could be a problem with your mouse driver software?
    the body of water is the atlantic ocean, on the coast of maine in the northeast US. i used to be a lobster fisherman there.
  5. #5
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Check the variable TRACKPATH, mine is set to 0 and I see both dotted lines.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
  6. #6
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    Should we be adding this info to FAQ database? maybe tacking it onto another question we've already got in there?
    bookmarked
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  7. #7
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Both lines will not show up until you place your cursor at the intersection. If you try zooming during the operation you will lose the points and will need to reselect.
  1. How can I use tracking to start a line from an existing line
    By g-dub in forum AutoCAD Beginners' Area
    Last Post: 29th Jul 2010, 03:31 am
  2. polar tracking
    By good_m in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2006, 01:46 pm
  3. Polar Tracking
    By EvilRufusKay in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Nov 2005, 05:29 pm
  4. Tracking a line
    By Valery Kichenko in forum AutoCAD Beginners' Area
    Last Post: 9th Jul 2005, 09:18 pm
  5. tracking drawings?
    By kibber in forum AutoCAD General
    Last Post: 11th Nov 2003, 11:59 pm
