Results 1 to 7 of 7
Thread: offset
    Junior Member
    AutoCAD 2004
    Jul 2007
    Sydney Australia.
    10
    Default offset
    Hi,
    I have drawn a rectangle (using rectangle command) and I want to use the OFFSET command to dublicate one of the sides only.
    How can I do this without dublicating the whole rectangle.
    Thanks
    Greg
    Super Member profcad's Avatar
    profcad's Computer Details
    Windows Vista Ultimate
    Dell
    Dual - Six-Core Xeon
    12GB
    NVida 4400
    DUAL 22" WIDESCREEN
    Revit 2012
    Dec 2005
    Oklahoma City, OK
    825
    explode the rectangle first.
    John Helton
    Professor of CAD
    Oklahoma City Community College
    Oklahoma City, OK
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    how about drawing it using the LINE and FROM commands?
    and as this is AutoCAD and there's usually 7 different ways of doing things, can anybody else make another suggestion?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    Senior Member mrbucket's Avatar
    mrbucket's Computer Details
    Windows 7 Ultimate
    Antec 9Hundred
    ASRock A780GXE 128M
    AMD Phenom Quad 9950@3.0ghz
    4 Gigs OCZ Dominator@1333, 4 Gigs Flash Mem L3 Cache
    Radeon 8670 HD 1 gig
    Seagate Barracuda 500 Gig 16 mb Cache
    22" Sceptre HD
    Architecture 2010
    Aug 2007
    Brick, N.J. USA
    271
    Quote Originally Posted by profcad View Post
    This is the way to go.
    Or simply offset the entire object and explode the offset. Then delete the parts you don't need.
    My ESC key is worn out.
  5. #5
    Junior Member
    Mechanical 2007
    Aug 2007
    12
    All of the above. Or, draw the rectangle. Then, draw a line on the side you want to offset using osnap to grab the corners. Then, instead of offset, just move the line.
  6. #6
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    ... though it all depends on whether you want the line to be the same size as the one side, or if you want it to be extended as it would be if you OFFSET the whole rectangle
    what is it you're trying to do?
  7. #7
    Windows 7 Ultimate
    Antec 9Hundred
    ASRock A780GXE 128M
    22" Sceptre HD
    Architecture 2010
    Aug 2007
    Brick, N.J. USA
    271
    Quote Originally Posted by Strix View Post
    I can see how this gets a little frustrating. It could be something simple or something difficult. Maybe an "end result to be expected" should be attached.
  1. array offset..?
    By Rainy-Day in forum AutoCAD Drawing Management & Output
    Last Post: 30th Aug 2011, 09:40 am
  2. Dim offset?
    By RFRUSSO in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jul 2007, 12:08 am
  3. Offset <through>
    By Melinda Choppa in forum AutoCAD General
    Last Post: 6th Oct 2005, 12:33 am
  4. offset
    By joiner in forum AutoCAD Beginners' Area
    Last Post: 5th Apr 2005, 04:44 pm
