+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
  1. #1
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Sep 2007
    Posts
    69
    Drawing Dynamic Block, Centering Issues
    Hi everybody, I'm trying to make my horribly redundant job a lot easier with these dynamic blocks I keep hearing so much about , I'm having some issues with centering though. I have a rectangular window with lines running diagnally to indicate hinge direction. However, when I stretch the overall window, the diagonals get all messed up. I've read a few posts on this and attempted to set a 0.5 multiplier move action to the already stretching parameter, but it still gets screwed up. I'm just getting into this, so It could just be something stupid I'm overlooking. Thanks for any help you can provide! I've attached the DWG with the block. Thanks again!
  2. #2
    Super Moderator fuccaro's Avatar
    Using
    AutoCAD 2006
    Join Date
    Nov 2002
    Location
    Romania, Marosvasarhely
    Posts
    3,540
    Default
    Hello Pineapple!
    First of all: welcome in the forum!
    Could you please save the block back in 2006 version? This will give a chance to some more people to have a look.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  3. #3
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Sep 2007
    Posts
    69
    Default
    That's weird... no option for 2006 in the Save As box. 2004 is the latest one it has besides 2007... I saved it again as a 2004 file, but isn't that before Dynamic Blocks? I must be missing something
  4. #4
    Senior Member mrbucket's Avatar
    Computer Details
    mrbucket's Computer Details
    Operating System:
    Windows 7 Ultimate
    Computer:
    Antec 9Hundred
    Motherboard:
    ASRock A780GXE 128M
    CPU:
    AMD Phenom Quad 9950@3.0ghz
    RAM:
    4 Gigs OCZ Dominator@1333, 4 Gigs Flash Mem L3 Cache
    Graphics:
    Radeon 8670 HD 1 gig
    Primary Storage:
    Seagate Barracuda 500 Gig 16 mb Cache
    Monitor:
    22" Sceptre HD
    Using
    Architecture 2010
    Join Date
    Aug 2007
    Location
    Brick, N.J. USA
    Posts
    271
    Default
    The hinge lines "NEED" to be there? I am looking at it right now. The issue I am having with lines is that they are connect to multiple edges along several parameters. aka trying to make the lines stretch diagonally, vertically, and horizontal at the same time through one action while hitting 2+ point intersections. I don't know that this can be done.
    My ESC key is worn out.
  5. #5
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Sep 2007
    Posts
    69
    Default
    Yeah, I know it's kind of awkward. Those lines would eventually be controlled with a visibility parameter, so you could select which way the window opens. I don't think that helps any though....
  6. #6
    Computer Details
    Operating System:
    Windows 7 Ultimate
    Computer:
    Antec 9Hundred
    Motherboard:
    ASRock A780GXE 128M
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Monitor:
    22" Sceptre HD
    Using
    Architecture 2010
    Join Date
    Aug 2007
    Location
    Brick, N.J. USA
    Posts
    271
    Default
    The only thing I can suggest would be to put all parameters on a scaled increment, then like you said, change the visibility of the lines for each setting.
  7. #7
    Computer Details
    Operating System:
    Windows 7 Ultimate
    Computer:
    Antec 9Hundred
    Motherboard:
    ASRock A780GXE 128M
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Monitor:
    22" Sceptre HD
    Using
    Architecture 2010
    Join Date
    Aug 2007
    Location
    Brick, N.J. USA
    Posts
    271
    Default
    One more thought, are you using these windows alot? Or on one project, and thats it? Because it may be easier (not to take you away from all the fun) to just add the lines after placement.
  8. #8
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Sep 2007
    Posts
    69
    Default
    Unfortunately I use EXCLUSIVELY windows. I'm trying to refine the current way of doing things, which is just to draw EVERYTHING by hand - no blocks at all, and we're talkin about a lot of windows here!!! So I figured that If I'm gonna do it at all, I might as well do it right! I'm coming from a SolidWorks / ProE background, so I'm used to a more parametric/relationship based way of drawing.... This doesn't seem to be one of AutoCad's strong suits.
  9. #9
    Super Moderator Cad64's Avatar
    Computer Details
    Cad64's Computer Details
    Operating System:
    Windows 7 Profesional x64
    Computer:
    XI Computers
    Motherboard:
    Asus P8Z77-V Pro
    CPU:
    Intel Core I7 3770K 4.1 Ghz Quad Core 3rd Gen
    RAM:
    8GB DDR3 @ 1333MHz
    Graphics:
    Nvidia GeForce GTX 570 1280MB GDDR5
    Primary Storage:
    SATAII 500GB 7200 RPM
    Secondary Storage:
    Western Digital My Book Studio Edition II - 2TB capacity
    Monitor:
    HPf2105 21" LCD Widescreen & Cintiq 21ux
    Discipline
    Multi-disciplinary
    Cad64's Discipline Details
    Occupation
    Freelance Digital Artist
    Discipline
    Multi-disciplinary
    Details
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    Using
    3ds Max 2011
    Join Date
    Feb 2006
    Location
    Southern California
    Posts
    8,488
    Default
    Quote Originally Posted by Pineapple View Post
    There never was a 2006 file format. 2005 and 2006 both saved in 2004 format, so if you save in 2004 format, others with 2006 will be able to open your drawing and view your dynamic block. But if someone with 2004 or 2005 opens your drawing, they will just see a standard block.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  10. #10
    Computer Details
    Operating System:
    Windows 7 Ultimate
    Computer:
    Antec 9Hundred
    Motherboard:
    ASRock A780GXE 128M
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Monitor:
    22" Sceptre HD
    Using
    Architecture 2010
    Join Date
    Aug 2007
    Location
    Brick, N.J. USA
    Posts
    271
    Default
    Yeah I hear ya. I tried solidworks, I love the program but it is alot different, I guess you gotta put in the time.
    On your windows- If your dealing with the same manufacturer, make blocks for all the available sizes, and then I would (this is me) draw individual hinge lines, or include hinge swing on schedules with block markers. I guess it depends how big your jobs are.
Similar Threads
  1. Dynamic block with dynamic attributes
    By Helenka in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2012, 09:56 am
  2. Dynamic Block --- How do I???
    By WileCoyote365 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2007, 05:56 am
  3. Dynamic block?
    By alijahed in forum AutoCAD General
    Last Post: 8th May 2007, 12:01 am
  4. Block problems/issues
    By Jedidia in forum AutoCAD Drawing Management & Output
    Last Post: 5th Apr 2005, 03:34 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
