pause the cursor? not sure what you mean.
I am using Inventor Professional 2008 and would like to display the XYZ of the center of gravity(COG). I can get the COG symbol to display but when I pause the cursor (as the help file said to do) I get nothing. I have read through the help file and can not find anything wrong. Can some shed some light on this? Is this a bug?
Thanks,
Brian![]()
USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
If in doubt scale and don't ask!
The Inventor Pro 2008 help file said to do the following:
I have tried everything I can think of but nothing works. Any ideas?Can the COG's coordinate location be displayed?
You can display the exact coordinate location of the center of gravity by pausing the cursor over the COG symbol.
Tip: If the coordinates do not appear, ensure that the select mode is set to either Features or Features and Edges, and then click the right arrow on the Select Other tool. This selects the COG symbol. The coordinates should then display when you pause the cursor over the symbol.
Thanks,
Brian
...And have you done the rest of what is said?
"ensure that the select mode is set to either Features or Features and Edges, and then click the right arrow on the Select Other tool."
David
I am also using 2008 I have no problems viewing the data when I pause over the COG (just tried it) only thing I have done is downloaded the latest SP have you?
Can you post the file?
All I do is
view> center of gravity and pause mouse over the COG.
Sorry. The file when zipped is 1,514kb. Too large to upload.
I just opened the sample files and I get the same results. No information.
Thank,
Brian
