Results 1 to 4 of 4
    Junior Member
    AutoCAD 2007
    Sep 2007
    Malaysia
    19
    Default Join 2D polyline with poyline
    Can somebody tell me why i can't join these polylines?
    tq
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    The 2 grey polylines have a different z value to the yellow polyline. They are not coplanar, so they wont join. You have to make them all the same z value to join them.
    Use the express tool FLATTEN to bring them all to a zero "z" value.
    Junior Member
    AutoCAD 2007
    Sep 2007
    Malaysia
    19
    Thanks Allan
    Junior Member Ragnarok561's Avatar
    AutoCAD 2007
    Sep 2007
    11
    Or what you could of done in my aspect, is just type PEDIT then select what you wanted to join .
    After you click what you wanted to join, as you see the options that are on the command line, you will see join. You will type J then bamm.
    You press ESC then they should be joined
  1. polyline join & end styles
    By chulse in forum AutoCAD Drawing Management & Output
    Last Post: 10th Sep 2007, 06:04 pm
  2. Join 2d polyline to 3d polyline
    By Tconn in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jul 2007, 05:59 pm
  3. Join Points????
    By granthosie in forum AutoCAD Drawing Management & Output
    Last Post: 6th Nov 2006, 12:21 am
  4. newb! question - join polyline then fillet
    By pdlefief in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2006, 09:32 pm
  5. how do I join a spline to a polyline
    By rlackey in forum AutoCAD General
    Last Post: 15th Nov 2005, 07:37 pm
