Results 1 to 5 of 5
    Full Member
    AutoCAD 2008
    Sep 2007
    69
    Default Casement Window Swing Direction
    I just began working on building elevations and had a question about the convention used to indicate swing direction on casement windows. It seems like the standard in the US is to treat the window as if you are on the outside of the building, looking in. The indication would then be < for a left hinge and > for a right hinge. However, I've been told that this convention is different in Europe. Is this true, or are elevations always drawn with the same convention across the globe?
    The main confusion is that I believe the actual window manufacturer is in Europe and they require drawings with the opposite convention as the traditional US style, but I don't know if this is because they follow a different convention for elevations in Europe or if the manufacturer treats the windows as "inside-looking out" for production drawings.
    Thanks for your help in clearing things up!
    P.S. Yes, this is related to my dynamic block - centering issue post
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    I believe that in the UK at the very least, when doing any elevation type drawing, you treat the whole thing as "outside-looking-in"
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    here you are: http://www.jeld-wen.co.uk/?cmd=range...&id=33&info=39
    Windows viewed from outside
    that factory is in our village
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    Full Member
    AutoCAD 2008
    Sep 2007
    69
    Quote Originally Posted by NBC View Post
    Great, thanks a lot. I don't suppose you know if the opposite is true of production drawings sent to the manufacturer?
  5. #5
    Junior Member
    AutoCAD 2012
    Sep 2011
    16
    Quote Originally Posted by Pineapple View Post
    Yes, it is the opposite, actualy i was looking for confirmation of how it had to be done in US. Thanks. I just realized how old this is.
  1. Door Swing
    By slipperyer in forum AutoCAD Beginners' Area
    Last Post: 27th Dec 2011, 02:28 pm
  2. Scale in X-direction ONLY
    By feeneyje in forum AutoCAD General
    Last Post: 21st Aug 2010, 07:25 pm
  3. need direction
    By mightyblue in forum AutoCAD Beginners' Area
    Last Post: 21st Jun 2007, 09:13 pm
  4. Which Direction Next?
    By dadofmoos in forum AutoCAD Drawing Management & Output
    Last Post: 8th Feb 2007, 04:28 am
  5. Need some direction!
    By Vuelta in forum AutoCAD Beginners' Area
    Last Post: 11th Aug 2006, 09:55 pm
