Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member harshad's Avatar
    harshad's Computer Details
    XP
    INTEL 4
    1 GB
    120 GB
    SAMSUNG
    AutoCAD 2008
    Jul 2007
    mumbai, india
    61
    Love lisp want for increment
    hi friends
    i want a lisp for number or alphabetical increment
    lisp ask me for dist between text and increment valu
    this is need full i add the sample this is give u idia
    thanks
    harshad
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    try using the TCOUNT function of Express Tools.
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    NUM for inserting text, RENUM for changing existing text to numbers:
    Code:
    (defun c:num (/ oldPref oldSuf oldStart curStr newNum
               actDoc actSp oldEcho oldSize *error*)
      (defun *error* (msg)
        (setvar "CMDECHO" oldEcho)
        ); end *error*
      (vl-load-com)
      (if(not num:Size)(setq num:Size(getvar "DIMTXT")))
      (if(not num:Pref)(setq num:Pref ""))
      (if(not num:Suf)(setq num:Suf ""))
      (if(not num:Num)(setq num:Num 1))
      (setq oldPref num:Pref
            oldSuf num:Suf
            oldStart num:Num
       oldSize num:Size
       actDoc(vla-get-ActiveDocument
          (vlax-get-acad-object))
       oldEcho(getvar "CMDECHO")
       ); end setq
      (setvar "CMDECHO" 0)
      (if(= (vla-get-ActiveSpace actDoc) 1)
        (setq actSp(vla-get-ModelSpace actDoc))
        (setq actSp(vla-get-PaperSpace actDoc))
        ); end setq
      (setq num:Size
        (getreal
          (strcat "\nSpecify text size <"(rtos num:Size)">: ")))
      (if(null num:Size)(setq num:Size oldSize))
      (setq num:Pref
        (getstring T
          (strcat "\nType prefix: <"num:Pref">: ")))
      (if(= "" num:Pref)(setq num:Pref oldPref))
      (if(= " " num:Pref)(setq num:Pref ""))
      (setq num:Suf
        (getstring T
          (strcat "\nType suffix: <"num:Suf">: ")))
      (if(= "" num:Suf)(setq num:Suf oldSuf))
      (if(= " " num:Suf)(setq num:Suf ""))
      (setq num:Num
        (getint
          (strcat "\nEnter start number <"(itoa num:Num)">: ")))
      (if(null num:Num)(setq num:Num oldStart))
    (while T
      (setq curStr(strcat num:Pref(itoa num:Num)num:Suf)
            newNum(vla-AddText actSp
            curStr (vlax-3d-point
           '(0.0 0.0 0.0)) num:Size))
      (vla-put-Alignment newNum acAlignmentMiddleCenter)
      (command "_.copybase"(trans '(0.0 0.0 0.0)0 1)(entlast)"")
      (command "_.erase" (entlast) "")
      (command "_.pasteclip" pause)
        (setq num:Num(1+ num:Num))
      ); end while
      ); end of c:num
    (defun c:renum (/ oldPref oldSuf oldStart curText curStr)
      (vl-load-com)
      (if(not rnm:Pref)(setq rnm:Pref ""))
      (if(not rnm:Suf)(setq rnm:Suf ""))
      (if(not rnm:Start)(setq rnm:Start 1))
      (setq oldPref rnm:Pref
            oldSuf rnm:Suf
            oldStart rnm:Start); end setq
      (setq rnm:Pref
        (getstring T
          (strcat "\nType prefix: <"rnm:Pref">: ")))
      (if(= "" rnm:Pref)(setq rnm:Pref oldPref))
      (if(= " " rnm:Pref)(setq rnm:Pref ""))
      (setq rnm:Suf
        (getstring T
          (strcat "\nType suffix: <"rnm:Suf">: ")))
      (if(= "" rnm:Suf)(setq rnm:Suf oldSuf))
      (if(= " " rnm:Suf)(setq rnm:Suf ""))
      (setq rnm:Start
        (getint
             (itoa rnm:Start)">: ")))
      (if(null rnm:Start)(setq rnm:Start oldStart))
    (while T
      (setq curStr(strcat rnm:Pref(itoa rnm:Start)rnm:Suf))
        (setq curText
          (car
            (nentsel "\nSelect DText/MText/Attribute or Esc to Quit ")))
      (if
        (and
          curText
          (member(cdr(assoc 0(entget curText))) '("TEXT" "MTEXT" "ATTRIB"))
          ); end and
        (vla-put-TextString
          (vlax-ename->vla-object curText)curStr)
        (setq rnm:Start(1+ rnm:Start))
        ); end progn
        (princ "\nThis is not DText or MText! ")
        ); end if
      ); end while
      ); end of c:renum
    Super Member asos2000's Avatar
    asos2000's Computer Details
    WinXP
    AutoCAD 2007
    Sep 2007
    Cairo Egypt
    677
    thanx ASMI
    I was searching for that lisp which renumber attribute.
    can the increment start with 01 or 001
    and what about alphabet (A, B, C, .......Y, Z, AA, AB, ....etc)
    Sorry for my English.
  5. #5
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,539
    I believe my AutoNum V4 lisp has this function, choose to Pick Each Insert, and then hit R.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  6. #6
    Senior Member
    VVA's Computer Details
    Windows 7
    Intel Core i5-2400
    8 Gb
    Nvidia Quadro 600
    Seagate 500 GB + WD 750 GB
    Philips 27"
    AutoCAD 2013
    Dec 2006
    Minsk, Belarus
    447
    Quote Originally Posted by asos2000 View Post
    thanx ASMI
    Look this thread (How about ApnumA command?)
    And more link:
    Copying a number and increase the value at the same time
    I have a wonderful feature INCSUFF (Gilles Chanteau), I adapted it for the Russian alphabet. But Now I do not have time to adapt or write command: (
    Links to INCSUFF my adapted version:
    Attribute ASCII code +1
    Increment the suffix of a string
    Code:
    (defun incsuff (str inc alpha / lst crt pas ind dep quo ret)
    ;; INCSUFF -Gilles Chanteau- 2008/01/15
    ;; Adds the specified increment to a string suffix.
    ;; Is considered as suffix, all [0-9] characters from the end of the string
    ;; more [A-Z] and [a-z] characters if alpha argument is non nil.
    ;; Adapting to the Russian alphabet VVA (Vladimir Azarko)
    ;; Arguments
    ;; str : a string
    ;; inc : a positive integer
    ;; alpha : if non nil, [a-z] [A-Z] characters are integrated to suffix.
    ;; Return
    ;; The string with incremented suffix (or nil if none valid suffix)
    ;; Examples :
    ;; (incsuff "N° 002" 12 T) = "N° 014"
    ;; (incsuff "Drawing_A" 1 T) = "Drawing_B"
    ;; (incsuff "test_ZZ9" 1 T) = "test_AAA0"
    ;; (incsuff "test_ZZ9" 1 nil) = "test_ZZ10"
    ;; (incsuff "12-" 1 nil) = nil
      (setq lst (reverse (vl-string->list str)))
      (while
        (and
          (setq crt (car lst))
          (cond
            ((< 47 crt 58) ;_Number
             (setq pas 10  ;_Step
                   ind 48  ;_ ASCII Code Number 0
             ) ;_ end of setq
            ((and alpha (< 64 crt 91)) ;_Upper case latin
             (setq pas 26              ;_Number of letters in the alphabet (step)
                   ind 65              ;_Upper case latin A (eng)
             ) ;_ end of setq
            ((and alpha (< 96 crt 123)) ;_Lower case latin
                   ind 97               ;_Lower case latin A (eng)
             ) ;_ end of setq
            ((and alpha (< 191 crt 224));_Upper case russian
             (setq pas 32               ;_Number of letters in the alphabet (step)
                   ind 192              ;_Upper case russian A
             ) ;_ end of setq
            ((and alpha (< 223 crt 256));_Lower case russian
                   ind 224              ;_Lower case russian A
             ) ;_ end of setq
            ((< 0 quo)
             (setq crt (if (= 10 pas)
                         ind
                         (1- ind)
                       ) ;_ end of if
                   lst (cons (car lst) lst)
             ) ;_ end of setq
          ) ;_ end of cond
        ) ;_ end of and
         (setq dep (- crt ind)
               quo (/ (+ dep inc) pas)
               ret (cons (+ ind (rem (+ dep inc) pas)) ret)
         ) ;_ end of setq
         (if (zerop quo)
           (setq ret (append (reverse (cdr lst)) ret)
                 lst nil
           ) ;_ end of setq
           (if (cdr lst)
             (setq lst (cdr lst)
                   inc quo
             ) ;_ end of setq
             (setq lst (list ind)
                   inc (if (= 10 pas)
                         quo
                         (1- quo)
                       ) ;_ end of if
             ) ;_ end of setq
           ) ;_ end of if
         ) ;_ end of if
      ) ;_ end of while
      (if ret
        (vl-list->string ret)
      ) ;_ end of if
    ) ;_ end of defun
  7. #7
    Senior Member
    Windows 7
    Intel Core i5-2400
    8 Gb
    Nvidia Quadro 600
    Philips 27"
    AutoCAD 2013
    Dec 2006
    Minsk, Belarus
    447
    Try it. Number
    Code:
    (defun c:numA (/ oldPref oldSuf oldStart curStr newNum
               actDoc actSp oldEcho oldSize *error* tmpstr)
    ;;; Numeric with alignment (add 0 before number) of number
    ;;;Edition 15.17.2009 Vladimir Azarko (VVA)
    ;;;http://www.cadtutor.net/forum/showthread.php?p=253543
        (princ msg)(princ)
        ); end *error*
      (vl-load-com)
      (if(not num:Alig)(setq num:Alig "1"))
            oldSuf num:Suf
            oldStart num:Num
       oldSize num:Size
       ); end setq
        ); end setq
      (setq num:Size
        (getreal
      (setq num:Pref
        (getstring T
          (strcat "\nType prefix:(If you want to delete prefix type ' ' (press SPACE key on keyboard) <"num:Pref"> :")))
      (setq num:Suf
        (getstring T
          (strcat "\nType suffix:(If you want to delete prefix type ' ' (press SPACE key on keyboard) <"num:Suf"> :")))
    (setq  oldStart num:Alig)
    (initget "1 10 100 1000 10000 100000")
    (setq num:Alig
        (GETKWORD
          (strcat "\nSpecify alignment of number [1/10/100/1000/10000/100000] <"num:Alig">: ")))
      (if(null num:Alig)(setq num:Alig oldStart))
      (setq  oldStart num:Num)
      (setq num:Num
        (getint
    (while T
      (setq oldStart (itoa num:Num))
      (while (<= (strlen oldStart)(1- (strlen num:Alig)))
        (setq oldStart (strcat "0" oldStart)))
      (setq curStr(strcat num:Pref oldStart num:Suf)
      ); end while
      ); end of c:numA
  8. #8
    Senior Member
    Windows 7
    Intel Core i5-2400
    8 Gb
    Nvidia Quadro 600
    Philips 27"
    AutoCAD 2013
    Dec 2006
    Minsk, Belarus
    447
    And renumber
    Code:
    (defun c:renumA (/ oldPref oldSuf oldStart curText curStr vlaObj keepText ss)
     ;;;Routine for Renumbering
    ;;;Realization {Smirnoff} aka ASMI
    ;;;http://www.autocad.ru/cgi-bin/f1/board.cgi?t=30394Ae
    ;;;http://www.caduser.ru/cgi-bin/f1/board.cgi?t=29829Am
    ;;;http://www.autocad.ru/cgi-bin/f1/board.cgi?t=21807yD
    ;;;Edition 23.10.2006 Vladimir Azarko (VVA)
    (vl-load-com)
    (defun TTC_Paste(pasteStr keepText / nslLst vlaObj)
    (if (setq nslLst(nentsel "\nPaste text <exit> >>"))
      (cond
    ((and (= 4(length nslLst))
     (= "DIMENSION"(cdr(assoc 0(entget(car(last nslLst))))))); end and
    (setq vlaObj (vlax-ename->vla-object (cdr(assoc -1(entget(car(last nslLst)))))))
    (setq oldStat (vla-get-Measurement vlaObj))
    (if keepText
     (if (= (vla-get-TextOverride vlaObj) "")
     (setq pasteStr (strcat pasteStr (rtos oldStat (vla-get-UnitsFormat vlaObj) (vla-get-PrimaryUnitsPrecision vlaObj))))
     (setq pasteStr (strcat pasteStr (vla-get-TextOverride vlaObj)))))
    (if (vl-catch-all-error-p(vl-catch-all-apply 'vla-put-TextOverride(list vlaObj pasteStr)))
     (princ "\n Can't paste. Object may be on locked layer. "))); end condition #1
    (= "ACAD_TABLE"(cdr(assoc 0(entget(car(last nslLst))))))); end and
    (setq vlaObj (vlax-ename->vla-object(car nslLst)))
    (if keepText (setq pasteStr (strcat pasteStr (vla-get-TextString vlaobj))))
    (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-TextString(list vlaObj pasteStr)))
    (princ "\nError. Can't pase text. ")(entupd (car(last nslLst))))); end condition # 2
     (= "INSERT"(cdr(assoc 0(entget(car(last nslLst))))))); end and
    (princ "\nCan't paste to block's DText or MText. ")); end condition #3
    ((and (= 2(length nslLst))
    (member(cdr(assoc 0(entget(car nslLst)))) '("TEXT" "MTEXT" "ATTRIB" "ATTDEF"))); end and
    (princ "\nError. Can't pase text. "))); end condition #4
    (T (princ "\nCan't paste. Invalid object. ")); end condition #5
    ); end cond
    T); end progn
    nil); end if
    );_TTC_PASTE
    (setq aDoc(vla-get-ActiveDocument(vlax-get-acad-object)))
    (vla-StartUndoMark aDoc)
    (if(not rnm:Pref)(setq rnm:Pref ""))(if(not rnm:Suf)(setq rnm:Suf ""))
    (setq oldPref rnm:Pref oldSuf rnm:Suf); end setq
    (setq rnm:Pref (getstring T
    		 (strcat "\nType prefix:(If you want to delete prefix type ' ' (press SPACE key on keyboard) <" rnm:Pref "> :")))
    (if(= "" rnm:Pref)(setq rnm:Pref oldPref))(if(= " " rnm:Pref)(setq rnm:Pref ""))
    (setq rnm:Suf (getstring T
                    (strcat "\nType suffix:(If you want to delete prefix type ' ' (press SPACE key on keyboard) <"rnm:Suf"> :")))
    (if(= "" rnm:Suf)(setq rnm:Suf oldSuf))(if(= " " rnm:Suf)(setq rnm:Suf ""))
    (setq num:Alig
        (GETKWORD
    (setq  oldStart rnm:Start rnm:Start (getint (strcat "\nEnter start number <"
    (initget "Yes No ?? ??? _Yes No Yes No")
    (setq keepText (not (= "No" (getkword "\nkeep contents of the text [Yes/No] <Yes>:"))))
    (setq rnm:Start (1- rnm:Start))
    (while
      (setq oldStart (itoa (setq rnm:Start(1+ rnm:Start))))
      (TTC_Paste (setq curStr(strcat rnm:Pref oldStart rnm:Suf)) keepText)))
    (vla-EndUndoMark aDoc)(princ)); end of c:renumA
  9. #9
    WinXP
    AutoCAD 2007
    Sep 2007
    Cairo Egypt
    677
    Is there an English version of www.autocad.ru site
  10. #10
    WinXP
    AutoCAD 2007
    Sep 2007
    Cairo Egypt
    677
    How can i change the default answer is No
  1. Increment value Lisp needed (with frames)
    By janisa in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Nov 2011, 12:51 pm
  2. problem, trying to running a list of lisp from within a lisp
    By twind2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2007, 04:27 pm
  3. calling another lisp from within my lisp
    By thalon in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Feb 2006, 09:56 pm
  4. Increment Number automatically
    By RCFun in forum AutoCAD General
    Last Post: 8th Aug 2003, 11:35 pm
