Results 1 to 4 of 4
    Kollargoll
    Question Attribute Extraction, fully automatic
    Hello
    I would like the EATTEXT to run through all the 6 pages with a certain sett of detailed settings is this possible? How to thick off the check boxes and choose the right *.blk file for extraction?
    Anyone have any ideas..
    Full Member
    AutoCAD 2004
    Aug 2007
    80
    play around with "-eattext" and you should be able to scrip it to a menu button
    ...And someday, they will have computers the size of houses, with millions of vacuum tubes, doing thousands of computations per minute...!!!
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    I prefer the old ATTEXT command.
    Try it manually first. Make a template file as described in Help.
    Then make a macro for it using -ATTEXT.
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
    Kollargoll
    This one works ok for me
    [CODE];;Made By Rune Bringedal
    ;;21. Sept. 2007
    (defun PBEATTEXT()
    (command "eattext" "Currentdwg" "No" "No" "Yes")
    (command "C:\\mycmd\\PB\\TEMPLATE\\EXTRACT\\All.blk")
    (command "Xls")
    (command "C:\\myspace\\PB\\EXPFILE\\eex.xls")
    (command "Yes")
    (Princ)
    [CODE]
  1. Attribute Extraction Program?
    By tkwon in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jun 2012, 08:03 pm
  2. Editing attribute extraction table settings
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 9th Nov 2006, 07:50 pm
  3. attribute extraction in AutoCAD LT 2007
    By Robert Whiting in forum AutoCAD General
    Last Post: 30th Sep 2006, 01:42 pm
  4. Attribute extraction and Fields question
    By MRSWOLF in forum AutoCAD Drawing Management & Output
    Last Post: 11th Nov 2005, 05:39 pm
  5. Attribute Extraction in inches AutoCAD lt 2004
    By makisupa in forum AutoCAD Beginners' Area
    Last Post: 21st Apr 2005, 02:56 pm
