Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    Forum Newbie Shanna's Avatar
    AutoCAD 2006
    Sep 2007
    7
    Question Making Sure Lines Are Truly Connected
    Good Morning,
    I work for a company that does custom coutertops and showers, and I use AutoCad 2006 to create the .dxf files that we use on the Saw and on our CNC machine. My problem is that the lines show up connected in my AutoCad but when they put it on the CNC it zooms in like 3 times the amount that autocad will and shows that part of the lines are not truly connected together. We had a tech. guy come yesterday and he used a different program ( InterCAD I think) and he had a command called continuity that showed if the lines where truly connected and if they weren't then it would put a symbol showing where it wasn't connected. I told the guy that I had never heard of that command in AutoCad but he said that his InterCad was a piggyback program of AutoCAD so it should have on there but I can't find it. So if anyone knows about this command or another command in AutoCad 2006 that will allow me to fix this problem I would really be greatful because right now I draw the files then take them to the guys in the shop then have to go back and get them and spend forever trying to redit them to where it will work.
    Thanks
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    The command you want is PLINE. That will create a polyline.
    Other than that, if you want to join a lot of LINES together. then use PEDIT, and follow the on command line prompts.
    Best of luck.
    Senior Member
    AutoCAD 2008
    Aug 2006
    Northern Ireland ( Norn Iron )
    134
    Welcome Shanna to the forum!
    Are you using the autosnaps?
    TOOLS - DRAFTING SETTINGS - OBJECT SNAP.
    Try using also the FILLET command for corners.
    Fillet set to 0.
    What about joining up lines into polylines?
    Maybe you know all this already and the other program does things to the AutoCAD drawing...?!
    Stephen
    AutoCAD 2006
    Sep 2007
    7
    Problem is the CNC doesn't reconize Polylines they have to be regular lines for them to show up at all on it and yes my snaps are on and on autocad it shows that the lines are snapped to the end points or where they need to be but the CNC zooms in so much further that it shows the teeny tiny inperfections and it stops the CNC from running
  5. #5
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    I haven't heard of a prog to do this in AutoCAD but if I ever want to check an area for continuity I highlight all of the entities then go round the endpoint grips... if only one entity stretches where 2 or more should intersect then I know that they don't meet properly
    Only the lonely only ... PhotoGallery / Music
  6. #6
    Map 3D 2009
    Jun 2006
    4,181
    ????????? ..... what the?????
  7. #7
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    You could use the Pedit>>Multiple command to join all your lines/arcs to polylines. If they don't join you'll know you have gaps. Then use a "fuzz distance" (gap tolerance) large enough that causes them to join. Your gaps will then be fixed. Now use "explode" command to turn polylines back to arc & line segments.
    Command sequence will look something like this:
    Command: pedit
    Select polyline or [Multiple]: m
    Select objects: Specify opposite corner: 3 found
    Select objects:<return>
    Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j
    Join Type = Extend
    Enter fuzz distance or [Jointype] <0.1000>: 1
    2 segments added to polyline
  8. #8
    AutoCAD 2006
    Sep 2007
    7
    Idea
    Thanks
    I really didn't think about that but I could try turning them into polylines and then just exploding them back to lines. I'll let you all know if it works.
    thanks
  9. #9
    AutoCAD 2006
    Sep 2007
    7
    It didn't work it still showed up as having broken lines when I turn them into polylines and then explode them
  10. #10
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    I'm fascinated by the concept of unjoined lines in AutoCAD
    how the heck does that happen at all?
    you say you're drawing with endsnaps etc?
    assuming what you're saying is true, would FILLET not sort that out?
    or EXTEND?
    can you tell us how far out your lines are falling from each other?
    you don't have something daft set like a grid snap do you?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  1. Having objects "stay connected" when moved
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jun 2007, 06:58 pm
  2. making center lines meet cleanly
    By the ber in forum AutoCAD Beginners' Area
    Last Post: 21st Feb 2007, 08:14 pm
  3. What should I be making /hr?
    By ChadPoehland in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jan 2007, 07:12 pm
  4. dotted lines plotting as solid lines
    By Dave^ in forum AutoCAD Beginners' Area
    Last Post: 11th Jan 2006, 01:16 pm
  5. Making a new .pgp
    By myk26 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jun 2004, 05:51 pm
