Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2007
    Sep 2007
    4
    Default Isometric dimension
    I'm using Autocad 2007 at home and Autocad 2004 at my school computer lab. and I have an assignment of this Isometric drawing. I need to put all dimensions and here I have problems to make the extension lines in isometric angle. Here are the snapshots of my work:-
    In autocad2004, I could put the extension lines in this way
    http://members.lycos.co.uk/kelseeexx/snap044.jpg
    but in autocad2007, the extension lines won't go parallel with the straight line. I used aligned dimension for both.
    http://members.lycos.co.uk/kelseeexx/snap043.jpg
    Any suggestion so that my dimensions can be exactly like in autocad 2004???
    thx in advance
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Move your UCS (0,0,0) on one of the end point of the line you want to dimension... and then use aligned dimension
    HAVE A NICE DAY
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 10
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Mechanical
    Lazer's Discipline Details
    Design Engineering Manager
    Mechanical
    Mechanical Designer using Autocad and Inventor
    Inventor 2018
    Aug 2005
    Northants, England
    1,819
    Or type UCS enter 3 now select 3 places on the cube to align your UCS
    USING AUTOCAD 2016 AND INVENTOR 2016, ALIAS 2016 SHOWCASE 2016.
    If in doubt scale and don't ask!
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    Guys... I don't think it's a 3d drawing... it's a 2d isometic.
    It works OK in 2007 & pretty much the way I remember it in 2004... _dimaligned & pick your points then _dimedit & Oblique & pick the dimension entity, then pick 2 points that you want to oblique to... in this case 2 points on the vertical line or type in 90. The text & arrows don't oblique any more for some reason (?) but the dim lines should be placed ok.
    Only the lonely only ... PhotoGallery / Music
  5. #5
    Windows 10
    8GB
    2TB
    Portable TB drive
    Mechanical
    Mechanical
    Inventor 2018
    Aug 2005
    Northants, England
    1,819
    Quote Originally Posted by Hedgehog View Post
    Hi Hedgehog, my way will still work if it's a 2d Isometric or a 3d model, all he will be doing us rotating his UCS so the X and Y are in the correct plane
  6. #6
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    I'm not sure, Lazer. If my memory is correct, isometric runs 30 degrees off the horizon both directions. That leaves a 120 degree gap, not 90 degrees. I guess he could do it by setting the ucs up for each side of the drawing.
    I'm just trying to think way back, so I could well be wrong.
  7. #7
    Map 3D 2009
    Jun 2006
    4,181
    I tried both methods, and I got nowhere. I guess I'm just dumb.
  8. #8
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    just out of curiosity... why are the arrowheads in the given example at a different orientation to the text in the dimension?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  9. #9
    Full Member
    AutoCAD 2008
    May 2007
    Derbyshire, U.K.
    89
    It is quite a long time since I dimensioned in isometric mode but if I remember correctly I used the method as described by Hedgehog with the appropriate obliquing angle - aligned and oblique dimensions are explained in AutoCAD help. Also, because I like my drawings to look right, I created text and arrow styles to align with the plane of the dimension. I don't know if that's the correct/best method but it works.
  10. #10
    Super Member chrisdarmanin's Avatar
    chrisdarmanin's Computer Details
    win 10
    HVAC
    chrisdarmanin's Discipline Details
    Building Services Draughtsman
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    yep hedgehog is right, i remember doing it in school
  1. Follow linear dimension with continued dimension
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 4th Aug 2007, 09:31 pm
  2. Isometric
    By Tatu100 in forum AutoCAD Drawing Management & Output
    Last Post: 26th Mar 2007, 08:40 pm
  3. Isometric car blocks
    By mattwsp in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2006, 02:16 pm
  4. 3D isometric to 2D
    By Salar in forum AutoCAD General
    Last Post: 3rd May 2006, 12:23 am
  5. Isometric
    By Jamma79 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Sep 2005, 04:57 am
