Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: reset autocad
    Full Member DavidB's Avatar
    AutoCAD 2008
    Sep 2007
    ste-Julienne, Québec
    62
    Default reset autocad
    i have a nice pack of small problem at work and i think they are all link to one thing. the previous guys. Not that my workflow is better but diferent. so i would like to reset autocad to its original state without reinstalling.
    In 3ds max i had only to junk a file name 3dsmax.ini. is there an equivalent in autocad? or some special step require, like leaving you pc 3 night under a full moon .
    "Dieu est le point tangent de zéro et de l'infini."
    DAO-Quebec
    BordeleauDesign
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    scroll down the page and click one of the threads that has already asked this question
    bookmarking for FAQ
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    AutoCAD 2008
    Sep 2007
    62
    okay i feel like a complete idiot here but i couldnt find the answer.
    Maybe i have sh*t in my eye but i saw nothing. and yes i tried the "search" so unless there a special name for the process other than "reset" well the other conclusion is;or i'm blind or i'm an idiot. both way arent very interesting
    DAO-Quebec
    BordeleauDesign
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    okay, you're right - most OPs have been interrogated further and solutions to the actual problem suggested
    what's gone wrong with your set up?
  5. #5
    Super Member JBullseye74's Avatar
    Construction
    JBullseye74's Discipline Details
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    773
    If you mean your workspace - click on pull down menu 'window' then select 'workspaces' then select 'autoCAD Default'
    I would probably make sure you save the existing one just in case.. !!
    AutoCAD 2010
    '"Accept that some days you're the pigeon, and some days you're the statue."
  6. #6
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,097
    Just reload AutoCAD.
  7. #7
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,640
    Type OPTIONS then look for the PROFILEs tab. The Vanilla resets back to plain but some settings stay.
    HTH
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
  8. #8
    AutoCAD 2008
    Sep 2007
    62
    thanks all try it ASAP
    -D-
    DAO-Quebec
    BordeleauDesign
  9. #9
    Forum Newbie
    AutoCAD 2010
    Aug 2010
    2
    Hi Everyone,
    I’m a new member of this forum..
    I don’t know if I got the same problem but i also end up the conclusion to reset my CAD program.
    I’m using CAD 2010. I have a customized workspace based from the AutoCAD classic setting.
    These are the functions that are not working in my CAD:
    1. “Layers” toolbar (mini window) is freeze and won’t change to the assigned layer when I hit lines. Same thing with the “Properties” toolbar (mini window) won’t change also to each assigned layer and color. However drop down arrows are fine.
    2. “Viewport” toolbar (mini window) is freeze, it doesn’t give the assigned viewport scale every time I hit or switch my viewport to model.
    3. Double click editing for block objects won’t work even “Double click editing” in User Preferences @ “Options” is check. Only Edit Reference In-Place tool is working.
    I remember the last move I did was I copied detail from my old file in my old work to my current drawing then few minutes after I got this functions paralyzed. I don’t know if that one causes the problem.
    I tried to reset my profile back to vanilla @ Options as I read from the forum, everything was back to default except these problem.
    Generally, I can still continue working even without these functions but it annoys me so much and my working speed was already affected especially that I am just the only one working CAD guy in our office.
    Any opinions and solutions would be very much appreciated…
    God Bless,
    Dan
  10. #10
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Welcome to the CADTutor forum Dan.
    You somehow managed to dig up a thread from 2007.
    Normally we would ask that new questions be posted separately and not tacked onto another person's thread.
    But since your here let's see if we can solve your problem.
    I think that perhaps you should run the REPAIR option (found under Add/Remove programs). Do NOT uninstall then reinstall AutoCAD at least not yet.
  1. Keyboard shortcuts reset
    By Rainy-Day in forum AutoCAD Drawing Management & Output
    Last Post: 18th Feb 2010, 03:08 am
  2. Reset settings
    By stargirl23 in forum AutoCAD Beginners' Area
    Last Post: 18th Apr 2007, 09:13 am
  3. can i reset to autocad defaults?
    By charliefaison in forum AutoCAD Beginners' Area
    Last Post: 2nd Apr 2007, 10:13 pm
  4. how to reset F1 key
    By nivradolobo in forum AutoCAD Drawing Management & Output
    Last Post: 27th Feb 2007, 05:21 pm
  5. How do I cause the dimension to be reset to zero when I draw
    By seashell in forum AutoCAD Beginners' Area
    Last Post: 5th Apr 2005, 07:00 pm
