Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2004
    Oct 2007
    1
    Default linetype scale in Model Space/Paper Space
    Hi,
    I'm curious. I use 1:1 scale when drawing in model space. Normally it's a big architecture plan or some construction. When I use different linetype like dash or centre, the linetype scale is to small for my drawing thus not displayed as it should. So I change the linetype scale to make it show its true physical look. My problem happen when i want to plot the drawing. After scaling the drawing in paper space to fit the paper, I need to rescale the linetype once again to make it plot perfectly. if not, then my dash or centre line will be a solid line or missing.
    Is there any way to do this properly?
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    In MS set ltscale to 1. In PS set ltscale to suit the intended plot scale. Also set PSLTSCALE to suit (I always set it to 1). If you want to set ltscale to suit in MS so the lines look correct, just remember to set it back to 1 before you plot.
    Full Member
    AutoCAD 2007
    Feb 2007
    46
    My suggestion like Alan mentioned about setting your PSLTSCALE, I always set my PSLTSCALE to "0". The reason to this is because what I see in MS is what I will get once its plotted out. You don't have to worry about setting your ltscale.
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Quote Originally Posted by gofindsam View Post
    What happens when you have more than 1 differently scaled viewport on a layout ?
  5. #5
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    There are pro's & con's to both methods described & I use both depending on the drawing... the important thing is to understand what it's doing & why to make a judgement on how you want to approach it.
    Basically I always have the LTScale set to around 25 to 50 while I'm working in model space... if I have no linetypes to generate in Paperspace I'll usually leave it at the scale the viewport is zoomed to (eg 50) & set the PSLTscale to 0, however if I have other differently scaled viewports or a legend with linetypes in it I'll switch PSLTscale on & set the LTScale to 1 for plotting.
    Only the lonely only ... PhotoGallery / Music
  6. #6
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,133
    Try using a different LineType, such as HIDDENX2 instead of HIDDEN.
  1. LTSCALE - Model Space/Paper Space Differences and problems
    By Fedge in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2011, 02:33 pm
  2. Model Space to Paper Space and vise versa
    By J-LYLE in forum AutoCAD Drawing Management & Output
    Last Post: 4th Sep 2011, 08:14 am
  3. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
  4. Convert Paper Space to Model Space
    By irelandmc in forum AutoCAD Drawing Management & Output
    Last Post: 29th Nov 2006, 03:16 pm
  5. shortcut to toggle model space to paper space
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 3rd Feb 2006, 05:58 am
