Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 67
  1. #21
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    Why do you need to keep the selection window open whilst zooming?
    Finish the first selection window, THEN zoom, and add (or take away) to the selection when you are in close
    Do things in stages, if trying to do it all in one won't work.
  2. #22
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    I have the same set except;
    Selection Preview "when no command is active" is unchecked- I didn't like the screen flashing at me so much
    Selection Modes "associative hatching" is unchecked- but I'm guessing this won't affect it?
    I'm heading home now so will be keeping my fingers crossed for when I roll in at 7 tomorrow... bye for now!!!
  3. #23
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Quote Originally Posted by SLW210 View Post
    I will keep looking then, I know I fixed mine with a system variable. Just hard to track down how I fixed it.
    As you use 2008 version is not that a new feature? Only a guess, because I can't really solve the original problem.
    I've tried everithing, but when selecting things outside the displayed area are discarded from selection
    HAVE A NICE DAY
  4. #24
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    I believe I had it fixed on my 2000i version, I will double check, you may be correct.
  5. #25
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Quote Originally Posted by eldon View Post
    Good Morning!
    Thanks for the suggestion, and that's what I do right now, but I'm looking to speed up the process. As I mentioned it's for a specific area where I'm drawing timing diagrams and so if I need to move an entire row say 4 along, then to select it all would be easier, but accuracy is lost if you're drawing size is about 5200x 3000 and you're trying to pick out a line about 5200x 30- 150 while zoomed right out... does that make sense? It is early here lol...
  6. #26
    Super Member chrisdarmanin's Avatar
    chrisdarmanin's Computer Details
    win 10
    HVAC
    chrisdarmanin's Discipline Details
    Building Services Draughtsman
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    i know what you mean i have had that problem, here's what i do:
    Command: s STRETCH
    Select objects to stretch by crossing-window or crossing-polygon...
    Select objects: cp
    First polygon point:
    Specify endpoint of line or [Undo]:
    3 found
    Select objects:
    Specify base point or [Displacement] <Displacement>:
    Specify second point or <use first point as displacement>:
    before you start selecting you objects type CP (for crossing-polygon) and it still selects things that were selected before you zoom in, and it works from acad 2000 to 2008
  7. #27
    win 10
    HVAC
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    by the way its very accurate... i use it a lot
  8. #28
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Quote Originally Posted by chrisdarmanin View Post
    ...before you start selecting you objects type CP (for crossing-polygon) and it still selects things that were selected before you zoom in, and it works from acad 2000 to 2008
    Thanks Chris, I've had a quick look at this, but I think you've misunderstood? It's the items within the window I'm wanting to keep, not some individual items I've picked already... The CP command has the same result as a crossing window?
  9. #29
    win 10
    HVAC
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    yes it has the same results as a crossing window but when you pan or zoom what you've already selected out of the screen (while still selecting other objects) it still selects what's out of the screen
    i hope i made sense... my english is not so good
  10. #30
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Firstly, your English is fine, but unfortunately it's not the solution I'm looking for, thank's for looking at it though
  1. I need some help in Windows.....
    By tzframpton in forum AutoCAD General
    Last Post: 21st Apr 2006, 07:57 pm
  2. multiple windows
    By Carol in forum AutoCAD Beginners' Area
    Last Post: 18th Jan 2006, 05:23 pm
  3. delay in selection of objects/selection windows
    By RedRobMol in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2005, 01:34 pm
  4. windows XP
    By cadlad in forum AutoCAD General
    Last Post: 26th Feb 2004, 04:27 am
