Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2000
    Oct 2007
    6
    Default Mirror Text Problem
    I am having problems mirroring text in AutoCAD 2000. When MIRRTEXT is set to 1 and I mirror a block of text it mirrors correctly i.e. the text is back to front.
    However, when MIRRTEXT is set to 0 and I mirror a block of text it mirrors the text AND turns the text upside. The strange thing is that it turns each line upside down rather than the block of text i.e
    aaa
    bbb
    ccc
    The first line aaa would be mirrored back to front and upside but still remain as the first row of text and so on.
    This problem doesn't happen when creating a new drawing but happens between two machines running in the office, one with AutCAD 2000 and the other with AutoCAD 2004 LT.
    Please help as this is extremely annoying and time consuming to amend.
    Many thanks.
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    I've had this once before in 2000 but they must have fixed it in the newer releases 'cos I can't reproduce it here... from memory I'd check the STYLE dialogue for the various text styles & make sure that none of them have the Upside down or Backwards boxes ticked.
    Only the lonely only ... PhotoGallery / Music
    XP sp 3
    MEP 2009
    Aug 2007
    896
    By ' block of text' do you mean an MTEXT entity, a number of DTEXT entities or a block with either text or attribute entities?
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    I would suggest go check out MIRRTEXT in the acad help.....not that it will help you much, but a good starting point.
    acad help leaves a lot to be desired.
    Failing that, keep asking here.
  5. #5
    Forum Newbie
    AutoCAD 2000
    Oct 2007
    6
    By block of text I meant multiline text.
    AutoCAD help is about as useful as a chocolate teapot!
  6. #6
    XP sp 3
    MEP 2009
    Aug 2007
    896
    It's a glitch... I wish I had an older version here 'cos I remember the problem... are there any rotated UCS's in the drawing (or could the text have been created in a different UCS)? It could be trying to revert to it's original UCS.
  7. #7
    XP sp 3
    MEP 2009
    Aug 2007
    896
    Not a solution but you're not alone...
    http://forums.augi.com/showthread.php?t=42844
  8. #8
    Forum Newbie
    AutoCAD 2000
    Oct 2007
    6
    Thanks for the help.
    I think you are right, it may be UCS related.
    I have been having a play with it creating new text on the world UCS which mirrors correctly. Then I checked the properties of the good text against the bad text in Multiline Text Editor where it both texts had a different style uner the properties tab. The good text had style 'ROMANS' and the bad text had style 'SMALL'. So I selected the bad text and changed to 'ROMANS' in Multiline Text Editor and Bob's your uncle it now mirrors correctly. All I need to do now is match properties for the rest of the bad text in the drawing.
    Many thanks.
  1. Mirror and text
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 13th Sep 2007, 11:32 am
  2. Help with block mirror .... please
    By WileCoyote365 in forum AutoCAD Drawing Management & Output
    Last Post: 11th Aug 2007, 07:04 pm
  3. Mirror Blocks
    By cmrao in forum AutoCAD Beginners' Area
    Last Post: 8th Mar 2007, 10:46 am
  4. mirror command
    By ollie in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Mar 2007, 09:10 am
  5. Dimension Text mirror problems
    By Mark Young in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jan 2006, 04:31 pm
