Results 1 to 10 of 10
    Senior Member
    not specified
    Feb 2006
    243
    Default grips for attribute in block
    hello to all
    i was making block with attribute in previous version of autocad (2002 -2004)
    i can move this attribute because it has a grip now in cad2008 i can't see grips for attribute any explantion please
    i want to see grip for every attribute to enable me to move it to a suitable location
    thanks
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    Do you have grips turned on?
    Full Member Mr Cory's Avatar
    Architectural DT 2007
    Sep 2007
    Invercargill, New Zealand
    37
    Are the attributes set to lock position?
    New Zealand
    ADT 07 SP2
    $100 worth of your time?
    A man may fall many times but he has not failed until he refuses fot get back up.
    A succussful person is the one who can lay a firm foundation with the bricks that others throw at him/her.
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Be sure that GRIPBLOCK is set to 1
    And as suggested above
    1. Click Tools menu » Options.
    2. In the Options dialog box, Selection tab, select Enable Grips.
    HAVE A NICE DAY
  5. #5
    Senior Member
    not specified
    Feb 2006
    243
    thank you for replies
    my problem is to move attributes so i need grips for these attributes not for block only
    when i made block with attributes only i can see grips for block
    thanks waiting replies
  6. #6
    Sep 2007
    37
    You could open the block in the block editor and add a point parameter and a move action for each attribute
    New Zealand
    ADT 07 SP2
  7. #7
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    As per Mr Cory, was the attribute created with "Lock position in block" checked on? If so you won't get grips for attributes. You can use Bedit and Properties to change the locked properties of the attribute. In the Block Editor click on the attribute, in Properties you can change the "Lock Position" from yes to no.
  8. #8
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    Quote Originally Posted by lpseifert View Post
    and once you do so you may need to use the attsync command on the block to update the attribute settings (but i haven't tested this myself)...
  9. #9
    Sep 2007
    37
    Quote Originally Posted by hazardman View Post
    Yeah you will have to
    New Zealand
    ADT 07 SP2
  10. #10
    Senior Member
    not specified
    Feb 2006
    243
    thanks to every one send reply
    the reason is i creat the block with lock position as a defualt option
    so the the problem happen
    thanks
  1. Adding an attribute to a block
    By Siberian in forum AutoCAD General
    Last Post: 17th Sep 2007, 09:35 pm
  2. Excel to block attribute
    By Thaumaturge in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jul 2007, 08:24 am
  3. Block attribute
    By rookie37 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Mar 2007, 02:11 am
  4. No block attribute entry - only block references
    By broadcastcad in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2006, 02:21 am
  5. block attribute question
    By bleeargh in forum AutoCAD Drawing Management & Output
    Last Post: 6th Oct 2005, 07:59 pm
