Results 1 to 4 of 4
    Forum Newbie Pen&Ink's Avatar
    AutoCAD 2008
    Oct 2007
    3
    Unhappy dimension Text fill problem
    Hi Anyone,
    am using Autocad 2008 & everytime i'm plotting my drawing to pdf. or simply plot it using this configured template(dwt) my dimensions text & arrows done from the model space appears to be in "outlined" form & when I do my dimensioning & texts from the layout space it appears okey on the plot output. here's a glimps of what it looks like. Hope you can help me figure/ fix this one as i want my dimension done on the model space.
    Senior Member GhostRider's Avatar
    GhostRider's Computer Details
    Windows10
    Dell XPS
    Dell
    Intell Core 2 DUO 2.8ghz
    32 GIG
    Nvidia
    160 Gigger
    Dual Dell
    Architectural
    GhostRider's Discipline Details
    Residential Engineering/Contracting
    Architectural
    AutoCAD 2018
    Aug 2007
    N. Carolina
    405
    Not sure I understand totally, the text is only outlined and not filled in?, does it do this with other Font styles or just that one
    So many commands, so little time....
    AutoCAD 2008
    Oct 2007
    3
    Default ey thankz for the post
    It does happen even on other text styles I do & by the way I used ARIAL text ( compressed by 8 ) for that style
    Windows10
    Dell XPS
    Dell
    32 GIG
    Nvidia
    160 Gigger
    Dual Dell
    Architectural
    Architectural
    AutoCAD 2018
    Aug 2007
    N. Carolina
    405
    Check the textfill I believe it should be set to 1 for filled text, if it is 0 it plots outlined text, this thread below explains it a bit more.
    http://www.cadtutor.net/forum/showth...=outlined+text
  1. Dimension Style text problem
    By Skeeps in forum AutoCAD Drawing Management & Output
    Last Post: 26th Sep 2007, 05:08 pm
  2. Text Fill
    By Howard.Wernow in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jul 2007, 04:01 pm
  3. Text & Solid Fill Hatching
    By gortex in forum AutoCAD Drawing Management & Output
    Last Post: 12th Dec 2006, 08:17 pm
  4. Selected text fill
    By givrdad in forum AutoCAD General
    Last Post: 8th Feb 2006, 11:23 pm
  5. Text Fill
    By FREEFORM in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2005, 03:08 pm
