+ Reply to Thread
Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 56 of 56
  1. #51
    Forum Deity NBC's Avatar
    Using
    AutoCAD 2009
    Join Date
    Aug 2007
    Location
    Manchester, UK
    Posts
    2,109
    Default
    using CANNOSCALE. set it to the exact same scale as the viewport; eg, if your viewport is scaled at 1:100, then your CANNOSCALE should be set to 1:100, etc etc
  2. #52
    Banned Alan Cullen's Avatar
    Using
    Map 3D 2009
    Join Date
    Jun 2006
    Location
    Cairns, Queensland, Australia
    Posts
    4,181
    Default
    Thanks, mate, I will try that when I get back to the office. But if it doesn't work, guess what ?
  3. #53
    Super Member happyunited's Avatar
    Using
    AutoCAD 2010
    Join Date
    Jun 2006
    Location
    Manchester, England
    Posts
    588
    Default
    just a quick one. when i do a dim command i get the measurement in mm how do i get it in m? i have changed my ddunits but no joy
  4. #54
    Using
    AutoCAD 2009
    Join Date
    Aug 2007
    Location
    Manchester, UK
    Posts
    2,109
    Default
    refer to a post i made on page 1 of this thread (the one with the image in it)
    and just do things in reverse.
  5. #55
    Using
    Map 3D 2009
    Join Date
    Jun 2006
    Location
    Posts
    4,181
    Default
    I think I have got a way around the text size in MS. We normally set everything up in MS, then when we are ready to start producing finished drawings, we create tabs and viewports, and go from there.
    Now we have to set up tabs and viewports straight away, and work in MS throught the viewports, that way everything looks how it should.
    As you said earlier about the introduction of PS, Blue. It just requires a slight change to your drawing practice, and all works well. And easy to adjust to.
  6. #56
    Using
    AutoCAD 2009
    Join Date
    Aug 2007
    Location
    Manchester, UK
    Posts
    2,109
    Default
    Quote Originally Posted by Alan Cullen View Post
    Is that as a result of the tutorial I sent you ?
    That is the easiest way I have found of using the annotative features efficiently so far.
Similar Threads
  1. Annotation Scaling 103
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 10th Jun 2009, 02:26 pm
  2. Annotation
    By Beale in forum AutoCAD General
    Last Post: 20th Jul 2007, 02:39 pm
  3. Annotation Scaling 106
    Last Post: 10th May 2007, 01:32 am
  4. Annotation Scaling 104
    Last Post: 18th Apr 2007, 05:40 pm
  5. Annotation Scaling 102
    Last Post: 4th Apr 2007, 06:20 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
